sonicFoam vs rhoCentralFoam forwardStep tutorial
Old   March 10, 2015, 14:59
Default sonicFoam vs rhoCentralFoam forwardStep tutorial
Hassan Kassem
hk318i is on a distinguished road
I run the forwardStep tutorial case for rhoCentralFoam and sonicFoam
till 10s. I am using the same mesh from the rhoCentralFoam tutorial and the same boundary conditions as well. The only different is the system folder which was copied from the tutorial of forwardStep of each solver.
Can anyone explain the attached results (Mach number) or it is a bug? BTW I run the original tutorials and I get similar results.
I am using OpenFOAM2.3.x using the latest update which rhoCentralFoam BCs were updated (3rd March 2015).
hk318i is offline   Reply With Quote
Old   March 12, 2015, 09:21
Matthias Neben
mneben is on a distinguished road
Hello hk318i,
the following paper compares these two solvers and maybe gives an explanation of your results
http://www.google.de/url?sa=t&rct=j&...87920726,d.ZWU
mneben is offline   Reply With Quote
Old   March 12, 2015, 12:15
Hassan Kassem
Originally Posted by mneben View Post
Hello hk318i,
Thank you for your response. Despite the differences between the two solvers, such big difference in results is not expected. It looks like if the sonicFoam case has higher back pressure than rhoCentralFoam. I checked the transient results which show that the sonicFoam predicted similar shock pattern at much earlier stage of the simulations time.
Adding adaptive mesh refinement to the forwardStep tutorial AlphaSheep OpenFOAM Running, Solving & CFD 10 August 3, 2019 15:40
rhoCentralFoam / sonicFoam VSass OpenFOAM Running, Solving & CFD 1 June 26, 2013 13:39
Running nacaAirfoil tutorial with sonicFoam nachettito OpenFOAM Running, Solving & CFD 0 July 26, 2012 09:43
Comparing compressible tutorial logs, biconic vs forwardStep clc OpenFOAM Running, Solving & CFD 1 May 1, 2011 11:34
SonicFoam forwardStep Tutorial OF 14 tutlhino OpenFOAM Running, Solving & CFD 16 May 1, 2008 17:09
