Strange behaviour when using compressibleInterFoam with constantAlphaContactAngle |
March 10, 2015, 08:39 |
Rep Power: 12 |
I have a test case, which is a rectangular box with a rectangular outlet. The box is filled with a fluid which flows out of the box due to gravity (refer to attached screenshot). The mesh is created with blockMesh and has a cell size of 1mm. The solver used is compressibleInterFoam in the 2.3.x version and no turbulence model is used --> laminar. Boundary Conditions: p_rgh: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object p_rgh; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [ 1 -1 -2 0 0 0 0 ]; internalField uniform 100000.0; boundaryField { Box_inlet { type totalPressure; U U; phi phi; rho rho; psi none; gamma 1.4; p0 uniform 100000.0; } Box_sideWalls { type fixedFluxPressure; } Box_bottomWall { type fixedFluxPressure; } Outlet_walls { type fixedFluxPressure; } Outlet_bottom { type totalPressure; U U; phi phi; rho rho; psi none; gamma 1.4; p0 uniform 100000.0; } } calculated on all patches T: at walls fixedValue and at inlet and outlet zeroGradient U: Code:
FoamFile { version 2.3.0; format ascii; class volVectorField; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [ 0 1 -1 0 0 0 0 ]; internalField uniform (0 0 0); boundaryField { Box_inlet { type pressureInletOutletVelocity; value uniform (0 0 0); } Box_sideWalls { type fixedValue; value uniform (0 0 0); } Box_bottomWall { type fixedValue; value uniform (0 0 0); } Outlet_bottom { type pressureInletOutletVelocity; value uniform (0 0 0); } Outlet_walls { type fixedValue; value uniform (0 0 0); } } alpha.water: Code:
FoamFile { version 2.3.0; format ascii; class volScalarField; object alpha.water; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [ 0 0 0 0 0 0 0 ]; internalField uniform 0; boundaryField { Box_inlet { type inletOutlet; inletValue uniform 0; value uniform 0; } Box_sideWalls { type constantAlphaContactAngle; theta0 10; limit gradient; value uniform 0; } Outlet_walls { type constantAlphaContactAngle; theta0 10; limit gradient; value uniform 0; } Outlet_bottom { type inletOutlet; inletValue uniform 0; value uniform 0; } Box_bottomWall { type constantAlphaContactAngle; theta0 10; limit gradient; value uniform 0; } } This behaviour can be observed for different viscosities and is only present when using constantAlphaContactAngle. Furthermore, the strange behaviour declines with increasing contact angle but does not vanish. Concerning the constantAlphaContactAngle BC: - when using limit none or alpha, the simulation diverges and alpha.water exceeds 1 - when using limit zeroGradient the fluid ascends only one or two cells According to the description of the BC limit zeroGradient Code:
// Set the gradient of alpha1 to 0 on the wall // i.e. reproduce previous behaviour A zeroGradient behaviour at the wall is only achieved, when the contact angle is set to 90°. Additionally the fvSolution and fvSchemes file: Code:
FoamFile { version 2.3.0; format ascii; class dictionary; location "system"; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { alpha.water { nAlphaCorr 1; nAlphaSubCycles 1; cAlpha 1; } pcorr { solver PCG; preconditioner { preconditioner GAMG; tolerance 1e-05; relTol 0; smoother DICGaussSeidel; nPreSweeps 0; nPostSweeps 2; nFinestSweeps 2; cacheAgglomeration true; nCellsInCoarsestLevel 10; agglomerator faceAreaPair; mergeLevels 1; } tolerance 1e-05; relTol 0; maxIter 100; } ".*(rho|rhoFinal)" { solver diagonal; } p_rgh { solver GAMG; tolerance 1e-07; relTol 0.01; smoother DIC; nPreSweeps 0; nPostSweeps 2; nFinestSweeps 2; cacheAgglomeration true; nCellsInCoarsestLevel 10; agglomerator faceAreaPair; mergeLevels 1; } p_rghFinal { solver PCG; preconditioner { preconditioner GAMG; tolerance 1e-07; relTol 0; nVcycles 2; smoother DICGaussSeidel; nPreSweeps 2; nPostSweeps 2; nFinestSweeps 2; cacheAgglomeration true; nCellsInCoarsestLevel 10; agglomerator faceAreaPair; mergeLevels 1; } tolerance 1e-07; relTol 0; maxIter 20; } U { solver smoothSolver; smoother GaussSeidel; tolerance 1e-06; relTol 0; nSweeps 1; } "(T|k|B|nuTilda).*" { solver smoothSolver; smoother symGaussSeidel; tolerance 1e-10; relTol 0; } } PIMPLE { momentumPredictor no; transonic no; nOuterCorrectors 1; nCorrectors 3; nNonOrthogonalCorrectors 0; } Code:
FoamFile { version 2.3.0; format ascii; class dictionary; location "system"; object fvSchemes; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ddtSchemes { default Euler; } gradSchemes { default Gauss linear; } divSchemes { div(phi,alpha) Gauss vanLeer; div(phirb,alpha) Gauss linear; div(rhoPhi,U) Gauss upwind; div(phi,thermo:rho.water) Gauss upwind; div(phi,thermo:rho.air) Gauss upwind; div(rhoPhi,T) Gauss upwind; div(rhoPhi,K) Gauss upwind; div(phi,p) Gauss upwind; div(phi,k) Gauss upwind; div((muEff*dev2(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear uncorrected; } interpolationSchemes { default linear; } snGradSchemes { default uncorrected; } fluxRequired { default no; p_rgh; pcorr; } Thanks Tobias |
March 17, 2015, 03:01 |
Rep Power: 12 |
If your need more information or further description of the case/problem, please ask for it.
Additional information: - the behaviour occurs regardless of mesh resolution - the simulation converges |
May 11, 2016, 06:34 |
Rohith
Rep Power: 14 |
Hi Tobias,
I have simulated paraffin and air in a similar test case. But have a better wetting rather smoother than what you have, I cannot really understand what could be the case. The small differences I suspect is that water has an acute wettability value greater than 10°, please try that if possible. BR, Rohith |
compressibleinterfoam, constantalphacontactangle, contact angle, interfoam |
strange pressure behaviour with symmetricPlane boudary condition - interFoam | duongquaphim | OpenFOAM Running, Solving & CFD | 10 | August 20, 2013 14:00 |
Strange residuals behaviour | xxxx | Main CFD Forum | 1 | July 13, 2013 14:40 |
Strange behaviour when using LienCubicKE and NonlinearKEShih | hani | OpenFOAM Running, Solving & CFD | 20 | March 6, 2013 10:06 |
Strange boundary behaviour using interFoam | Andrea_85 | OpenFOAM | 11 | January 22, 2013 15:09 |
strange behaviour of GGI in parallel on axis symmetrical case | A.Devesa | OpenFOAM Running, Solving & CFD | 0 | April 6, 2010 03:58 |
