the issue for TKE at wall
Old   March 10, 2015, 09:30
Default the issue for TKE at wall
Baek, Donghae
wes1204 is on a distinguished road
hello
I have a question on turbulence kinetic energy at wall.
when we use no-slip boundary conditon at wall, the velocity at wall is set to zero.
So velocity fluctuation is also zero because velocity is zero at the wall.
However TKE from openfoam has some value at the wall where velocity is set to zero (no-slip).
When I looked the value of TKE at wall using paraview, it is same to the value at cell centroid.
i used kqRWallFunction for k at solid wall. it may use zerogradient.
why zerogradient is applied for wall condition?
wes1204 is offline   Reply With Quote
Wall treatment with OpenFOAM roby OpenFOAM Running, Solving & CFD 48 May 28, 2021 12:38
help with wall functions Nick Georgiadis Main CFD Forum 10 January 17, 2017 11:03
Thin Wall Heat Transfer BC for rhoSimpleFoam swahono OpenFOAM Running, Solving & CFD 12 October 4, 2013 12:49
[Commercial meshers] tmerge utility creates unwanted interface/walls comes in the final mesh Shoonya OpenFOAM Meshing & Mesh Conversion 11 January 20, 2012 07:23
Wall function in adverse pressure gradients stephane baralon Main CFD Forum 11 September 2, 1999 05:05
