pressure sensor on a floating body
Old   March 9, 2015, 04:37
Default pressure sensor on a floating body
ashkan is on a distinguished road
Hi All,
I am modelling a floating body (tethered to sea bed) in waves using OpenFOAM 2.3 and waves2foam. I need to measure pressure on particular locations on the floating body. I Know that I can define probe locations in controlDict but as far as I understood that would work for fixed points but my points are located on the floating body, is there any way to do this in OF 2.3?
I would highly appreciate any comments.
Cheers
Ashkan
ashkan is offline   Reply With Quote
Old   March 9, 2015, 05:05
Yogesh Bapat
ybapat is on a distinguished road
Hello Ashkan,
If you look at probes.H in it has flag fixedLocations_. By default if is yes.
//- Fixed locations, default = yes
// Note: set to false for moving mesh calations where locations
// should move with the mesh
bool fixedLocations_;
I think you need to specify
fixedLocations no;
in probes dict in cotrolDict file .
Regards
-Yogesh
ybapat is offline   Reply With Quote
Old   March 9, 2015, 05:14
Originally Posted by ybapat View Post
Hello Ashkan,
fixedLocations no;
Regards
-Yogesh
Thanks Yogesh,
I had a look at the source code and it makes sense. As you said, I need to set fixedLocations = false
Many thanks again.
Ashkan
moving bodies, openfoam 2.3, probe pressure
6DOF with floating body bounce back. paka FLUENT 4 June 6, 2013 12:32
Pressure Rise Error emueller CFX 0 May 5, 2009 12:08
floating operating pressure and monitors force Lavastre jeremie FLUENT 2 September 7, 2007 09:10
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 03:15
Floating operating pressure antun FLUENT 0 January 14, 2004 05:15
