Slip vs. Symmetry boundary condition
Old   March 6, 2015, 14:57
Default Slip vs. Symmetry boundary condition
Madeleine P. Vincent
Madeleine P. Vincent is on a distinguished road
Hi all,
I am interested in the difference in OpenFOAM between a slip and a symmetry boundary condition for simpleFoam and pisoFoam, version 2.2.
Specifically, this is for a far field edge that should see flow almost entirely parallel to the wall. In this case I am looking at steady, incompressible flow, though later I will be looking at unsteady.
Does OpenFOAM calculate the two boundary conditions differently?
In this post:
http://www.cfd-online.com/Forums/ope...condition.html
it says that they are treated identically (except for perhaps pre- and post-processing).
However, when I switch my far-field BC's to slip from symmetry, the results are slightly different (in this case using simpleFoam). Thus I don't agree with the statements made in the post above.
[Perhaps OF has changed since that post was made, which would be an explanation.]
Does anyone have a good explanation?
Thanks,
Madeleine.
Madeleine P. Vincent is offline   Reply With Quote
Old   December 20, 2016, 08:38
Andela's Avatar
Marija Bervida
Andela is on a distinguished road
Dear all,
I am also interested in answer, so if anybody can explain it it would be nice.
Regards
*Things are not what they seem; nor are they otherwise.*
Andela is offline   Reply With Quote
Old   December 20, 2016, 12:07
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
Just take a look at two files:
1. $FOAM_SRC/finiteVolume/fields/fvPatchFields/basic/basicSymmetry/basicSymmetryFvPatchField.H
2. $FOAM_SRC/finiteVolume/fields/fvPatchFields/derived/slip/slipFvPatchField.H
slip is a child of basicSymmetry.
"the results are slightly different" from the post you are reviving means nothing without concrete numbers and figures.
alexeym is offline   Reply With Quote
boundary conditions, slip, symmetry
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
turbineSiting tutorial: slip condition at top boundary gives unexpected result letzel OpenFOAM 0 June 6, 2014 06:25
slip wall boundary condition mb.pejvak Main CFD Forum 5 May 24, 2014 07:49
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
