Foam::error::printStack(Foam::Ostream&) at ??:?
Old   March 2, 2015, 17:10
Default Foam::error::printStack(Foam::Ostream&) at ??:?
Julian
TulioVannu is on a distinguished road
Dear Foamers
I'm trying to solve this equation
    gradienteC = fvc::grad(C);
    dcdx = gradienteC.component(vector::X);
    Dw0 = turbulence->nu()/Sc;
   fvScalarMatrix depositionEqn
      Fm * rod * fvm::ddt(r1)
     - Dw0 * dcdx
Fm and rod are both constants, and Sc is the Schmidt Number defined as a constant
When i try to run it in my case it give me this error
DICPCG:  Solving for p_rgh, Initial residual = 1, Final residual = 0.005352, No Iterations 254
time step continuity errors : sum local = 0.00170013, global = 8.92372e-18, cumulative = 8.92372e-18
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigFpe::sigHandler(int) at ??:?
#2  Uninterpreted:
#3  Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) at ??:?
#4  Foam::operator/(Foam::UList<double> const&, Foam::UList<double> const&) at ??:?
#5  Foam::diagonalSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
#6  Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) at ??:?
#7  Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:?
 at ??:?
 at ??:?
#10  __libc_start_main at ??:?
#11
 at ??:?
Anyone knows what means this error? and how can it be solved??
Thanks to all
Julian
TulioVannu is offline   Reply With Quote
Old   December 17, 2018, 10:18
Jianrui Zeng
calf.Z is on a distinguished road
Have you solved this problem?I am interested in it, thank you.
calf.Z is offline   Reply With Quote
