sonicFoam not solving for U
Old   February 26, 2015, 12:29
Default sonicFoam not solving for U
c0sk is on a distinguished road
Hi all!!!
I am an experimentalist with some former experience with OpenFOAM. I am currently struggling to make a simple simualation work. The case is quite simple. An engine intake lip insde a rectangular mesh. I meshed it very simply with gmsh just to test the solver and to get the settings right. I used the sonicFoam RAS tutorial (NACA airfoil) to set up the case. Despite the fact that the case runs fine, the solver is actually not doing anything. I cant see any change in any of the variables in post processing and in the log file the number of iterations is 0 or sometimes 1 for most of the properties. I attached the start of the log file. I really dont know what I am missing.
Hope that someone could help me
Thank you so much!!
Edit: Can it be related to the fact that after I manually change front and back to empty the checkMesh utility results in :
Failed 1 mesh check??
c0sk is offline   Reply With Quote
simpleFoam error - "Floating point exception" mbcx4jc2 OpenFOAM Running, Solving & CFD 12 August 4, 2015 03:20
Unstabil Simulation with chtMultiRegionFoam mbay101 OpenFOAM Running, Solving & CFD 13 December 28, 2013 14:12
calculation stops after few time steps sivakumar OpenFOAM Running, Solving & CFD 7 March 17, 2013 07:37
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 12:16
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
