February 20, 2015, 12:18 |
Mixing two miscible fluids
Samuele Z
Rep Power: 19 |
Dear All,
I am looking for a solver that allows to solve the problem of 2 miscible fluids. Basically, I would need a simple (or pimple) foam, where I can add the transport equation for a passive scalar. The point is that the 2 liquids have different properties, hence I have to model the density and the viscosity of the mixture, also. Let me try to give you all the details: passiveScalar = alpha; LiquidaA (LA): density = rhoA; viscosity = nuA; LiquidaA (LB): density = rhoB; viscosity = nuB; alpha = fraction of the passive scalar of LA in a cell I start my simulation and I set alpha = 1 on inlet1 and alpha = 0 on inlet2. In a certain timestep, I do have - in a cell - alpha = alphaXXX: this means that I want to update the mixture properties like: rho = (rhoA*alphaXXX + rhoB(1-alphaXXX)) nu = (nuA*alphaXXX + nuB(1-alphaXXX)) considering that the total volume is exactly equal to the sum of volumeA and volumeB. Has anyone already written something similar? Could you kindly help? Thanks a lot, Samuele |
February 20, 2015, 12:37 |
Application twoLiquidMixingFoam Description Solver for mixing 2 incompressible fluids. Turbulence modelling is generic, i.e. laminar, RAS or LES may be selected. |
February 20, 2015, 12:39 |
Samuele Z
Rep Power: 19 |
Not exactly, twoLiquidMixingFoam (that is what I am using) consider the interfaces with the VoF. But it has to solve interface equations and it becomes slower and slower. I am looking for a much lighter tool.
Selection of Mixing Models for Miscible Fluids | equil | FLUENT | 0 | August 9, 2014 22:34 |
Mixing two miscible fluids | parradux | FLUENT | 0 | November 26, 2013 12:38 |
mixing of non reacting miscible fluids | Himanshu Arora | FLUENT | 0 | June 13, 2005 05:17 |
FIDAP-Properties Definition in Fluids Mixing Area | Q. Hao | FLUENT | 0 | February 17, 2005 13:00 |
turbulent mixing of two fluids | ulrich bieder | Main CFD Forum | 2 | October 9, 1999 17:15 |
