Boundary condition slip
Old   February 18, 2015, 05:43
Default Boundary condition slip
PLanger90 is on a distinguished road
i've got a question about the boundary condition "slip". In the UserGuide OpenFOAM defines slip boundary condition: "zeroGradient if φ is a scalar; if φ is a vector, normal component is fixedValue zero, tangential components are zeroGradient"
But I don't understand the definition "tangential components are zeroGradient" for velocity.
My problem is a test rig to visualize water flow around a zylinder. I've uploaded a picture.
I need the boundary condition for the free surface. I tested "zeroGradient" and "slip", because I won't simulate a multi-phase flow.
What's the better choice? I don't know the exact definition for the slip boundary condition.
Can somebody help me?
PLanger90 is offline   Reply With Quote
Old   February 18, 2015, 13:26
Thiago Parente Lima
thiagopl is on a distinguished road
A zero gradient for the tangencial velocity means a symmetry plane (roughly, it means that you have another identical experiment above yours). Notice that it is different from the no slip condition in which the tangencial velocity itself is zero.
In your experiment, apparently, only the flow around the cylinder is of your interest. Therefore, the experiment should be designed in a way that the upper and bottom boudaries do not affect the flow around the cylinder. If it is true, a symmetry plane in your simmulation would be a good choice.
But I have a question, this is a test rig for a Hele-Shaw flow visualization?
Last edited by thiagopl; February 18, 2015 at 13:34. Reason: Question added in the end
thiagopl is offline   Reply With Quote
Old   February 18, 2015, 14:09
Yes, I want to approximate a Hele-Shaw flow. But the distance between the front and the back wall is to large for a Hele-Shaw-Flow (10mm). And the boundary conditions are different. Therefore I will get significant deviations.
I have aalready been thinking to use a symmetry plane for the top of the test rig. But I'm also interested in the effect of the boundary conditions - in especially the boundary condition at the top of the test rig.
So which boundary condition should I use, to show the effect of the boundary conditions to the flow around the cylinder?
Old   February 18, 2015, 14:21
Thiago Parente Lima
PLanger90,
I suggest you to read the Breaking of a dam tutorial at the User Guide. The tutorial shows the treatment for the same boundary condition as yours, a surface free to the atmosphere.
Fields of interest: buoyantFoam, chtMultRegionFoam.
Old   February 18, 2015, 15:00
PLanger90,
Hi thiagopl,
i've already read the "Breaking of a dam" tutorial. In my simulation I used the solver simpleFoam.
For the pressure I used this boundary condition:
type totalPressure;
p0 uniform 0;
U U;
gamma 1;
value uniform 0;
And for the velocity:
type pressureInletOutletVelocity;
value uniform (0 0 0);
I uploaded a picture with the stream lines.
Obviously, this is wrong. But what's the mistake?
The second picture shows the solution with the "slip" boundary condition at the top of the test rig. When I use symmetryPlane, the solution is equal.
Thank's a lot for your help.
Old   February 18, 2015, 15:10
Originally Posted by PLanger90 View Post
Hi thiagopl,
type totalPressure;
p0 uniform 0;
U U;
gamma 1;
value uniform 0;
I forgot the second picture.
Old   February 19, 2015, 07:15
Thiago Parente Lima
You could write all your boundary conditions here (using [ CODE] [ / CODE] ), so it would be easier to find a problem. Before, check your fvSolutions or fvSchemes (sometimes we copy/paste some tutorials and forget to check them).
SLIP BOUNDARY CONDITION vas FLUENT 12 June 27, 2019 06:48
mixed inflow/outflow downstream boundary condition question peob OpenFOAM Running, Solving & CFD 3 February 3, 2017 11:54
Slip Boundary Condition over the curve wall Kelvin_mk OpenFOAM 1 March 15, 2014 05:02
CFX fails to calculate a diffuser pipe flow shenying0710 CFX 7 March 26, 2013 05:13
No Slip / 0 shear Boundary Condition evan FLUENT 0 July 29, 2004 14:37
