February 18, 2015, 01:30 |
FSI solver for compressible flow
Albin Johny
Rep Power: 12 |
Hello , I am a fresher in OpenFOAM. I have to do an FSI problem for a wing in a compressible flow. can anybody suggest me which solver i should be using.
I have tried in icoFsiFoam and icoFsiElasticNonLinULSolidFoam, since both are used for incompressible flows, I cannot use them. Can anybody kindly help, Please |
February 20, 2015, 11:12 |
Damon Lee
Rep Power: 12 |
I think you are going to need to edit icoFsiElasticNonLinULSolidFoam to make it compressible. I would resist using icoFsiFoam because I think it doesn't work in parallel.
If you look inside the solver the code inside the solveFluid.H is identical to icoFoam, you might be able to quickly make a solver by pasting the code from something like rhoPisoFoam into there and pasting the extra fields from that compressible solver into createfields.H. |
March 18, 2015, 01:53 |
Albin Johny
Rep Power: 12 |
sorry for the delay. I tried to add rhopisofoam to the icoFsiElasticNonLinULSolidFoam but the solver is not building in foam extend. it shows error. Is ther any thing i can do.
Thankyou |
March 18, 2015, 06:45 |
Damon Lee
Rep Power: 12 |
I wish I could help more but I am new aswell. icoFsiElasticNonLinULSolidFoam doesn't actually run in parallel, I have tried with proper HronTureckvalues and that doesn't work even with 2 cpus, also doesnt work on my own test geometry, and the solidMechanics support thread has several people with the same problem.
If you only want a steady state solution anyway then I would use icoFsiFoam and follow this report/tutorial: http://www.tfd.chalmers.se/~hani/kur...edAndFixed.pdf I have got cavitatingFoam(compressible solver) to work with it. the instructions work with foam-extend 3.1 mostly, but something needs to be done differently for it to compile, I think it was in createStressMesh.H. If you want to edit icoFsiElasticNonLinULSolidFoam then maybe you could post the code or tell the forum the compile error your getting? |
Solver for an incompressible, turbulent flow with heat transfer | tH3f0rC3 | OpenFOAM Running, Solving & CFD | 9 | June 17, 2019 07:12 |
thobois class engineTopoChangerMesh error | Peter_600 | OpenFOAM | 4 | August 2, 2014 10:52 |
Suitable solver for Air/Air flow with different temperatures | cjm | OpenFOAM | 1 | January 20, 2011 05:17 |
Troubleshooting Unsteady Incompressible Flow Solver | dandalf | Main CFD Forum | 0 | November 15, 2010 11:55 |
Fatal over flow in solver | Nandu | CFX | 5 | September 16, 2002 08:19 |
