IcoFoam stationary solution STRONGLY dependent on the tolerance of the linear solver
Old   February 14, 2015, 20:49
Exclamation IcoFoam stationary solution STRONGLY dependent on the tolerance of the linear solver
Sami
Mehrez is on a distinguished road
I would like to ask you if someone has tried to investigate the dependence of the flow regime (steady or unsteady) that is found by icoFoam Solver for a given problem on the tolerance set for the linear solver ?
In fact, as I reduce the solver tolerance, I notice that the Reynolds number corresponding to the onset of unsteady flow decreases.
Can you figure out how can this affect the accuracy of the results.
Thank you,
Mehrez
Mehrez is offline   Reply With Quote
Old   February 16, 2015, 07:59
Sami
Comments ?
icofoam, openfoam, steady and unsteady state, tolerance
Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam222/platforms/linux64GccDPO adarsh tiwari OpenFOAM Running, Solving & CFD 9 May 17, 2018 07:59
Drag force coefficient too high for a flow past a cylinder using komega sst Scabbard OpenFOAM Running, Solving & CFD 37 March 21, 2016 17:16
STL import is not working zordiack enGrid 9 July 1, 2014 15:49
Heat flux BC lfrigeri3 OpenFOAM 9 February 22, 2014 12:59
5.7.1 solver doing max coeff loops. Stevie Wonder CFX 5 July 5, 2005 13:31
