Saving & reading a field in only a part of the domain
Old   February 13, 2015, 05:02
Default Saving & reading a field in only a part of the domain
wc3speler is on a distinguished road
Hi everyone,
I was wondering if the following is possible in OpenFOAM: I have a mesh that has a uniform, rectangular mesh in the center of the domain with circular rings around it, as sketched in the attachment. I perform the following 2-step approach:
1) I calculate during the flowsimulation a certain field (the acoustic source) that has only a significant value in the small central part of the domain, while it is practically zero elsewhere (the propagation area). I output this field every time-step.
2) I start my acoustic simulation and read the source term that was written in step 1).
This approach works, but I'm not so happy with the disk-usage... Would it be possible to save the source only in the central part, which is then read again in step 2)?
Thanks alot!
wc3speler is offline   Reply With Quote
Old   February 19, 2015, 09:17
Shameless self-bump... No one knows or should I post this in the programming forum section?
acoustic source, aero-acoustics, coupling 2 solvers, i/o handeling
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
problems after decomposing for running alessio.nz OpenFOAM 7 March 5, 2021 05:49
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 20:43
Examining part of a Domain in Pointwise dilbert Pointwise & Gridgen 0 August 31, 2012 12:37
Access to Domain Pressure Field or mesh ar_mofidi OpenFOAM 0 April 12, 2010 07:47
