Absolute or relative pressures in cavitatingFoam
Old   February 10, 2015, 14:21
Default Absolute or relative pressures in cavitatingFoam
d.lagattolla is on a distinguished road
Hi guys! A simple question..I 'd like to know if the pressure values in the "p" file in the 0 folder for cavitatingFoam are absolute or relative pressures.
Thank you in advance!
d.lagattolla is offline   Reply With Quote
Old   February 11, 2015, 12:14
Damon Lee
D_LEE is on a distinguished road
I think that it is absolute pressure because in the solver there is no mention of atmospheric pressure.
That being said this is only going to change your answer by 1% as the low pressure boundary is 100e+05 Pa.
D_LEE is offline   Reply With Quote
Old   February 11, 2015, 13:29
Ok thank you!
Old   February 13, 2015, 12:38
Hey D_LEE I haven't quite understood yor second sentence.. what do you mean by "the low pressure boundary" being that value you said? What pressure are you referring to? Sorry i am totally new to OpenFOAM and there are a lot of things I don't know.
Thank you again for answering!
Old   February 13, 2015, 12:59
Damon Lee
In the throttle case, if you go to the 0/ directory you will see the boundary conditions for each field set for your case.
The pressure boundary condition is in p, and form there you can see that the boundary conditions of pressure force your fluid through the gap, the high pressure inlet is:
inlet
type totalPressure;
U U;
phi phiv;
rho rho;
psi none;
gamma 1;
p0 uniform 300e5;
and the low pressure outlet is:
outlet
type fixedValue;
value uniform 100e5;
both are units of Pa:
dimensions [1 -1 -2 0 0];
So when you are asking about the pressure being absolute or gauge pressure, its just going to change the boundaries by 1e5 Pa anyway so it probably wouldn't matter.
Old   February 13, 2015, 13:12
Ok i didn't realize you were talking about the tutorial specifically. Thank you very much!
[solidMechanics] Support thread for "Solid Mechanics Solvers added to OpenFOAM Extend" bigphil OpenFOAM CC Toolkits for Fluid-Structure Interaction 686 December 22, 2022 10:10
InterPhaseChangeFoam ERROR shipman OpenFOAM Running, Solving & CFD 37 March 23, 2014 13:43
how to compute relative velocity from absolute? spk Main CFD Forum 3 July 9, 2010 09:42
dynamic mesh, negative absolute pressures Jason FLUENT 0 March 15, 2005 10:36
Guage vs. Absolute pressures in Fluent. Riaan FLUENT 1 January 21, 2005 15:22
