February 1, 2015, 20:25 |
Boundary Conditions for reactingFoam
Rep Power: 13 |
I'm running a reactingFoam case with no reactions to track chemical species transport coming out the top of a vent stack with a crosswind.
Using the following thermophysical properties. type hePsiThermo; mixture reactingMixture; transport sutherland; thermo janaf; energy sensibleEnthalpy; equationOfState perfectGas; specie specie; I get about 1 second of run time (out of 20 seconds desired) before the simulation crashes. I get a temperature spike, the time step decreases to infinitesimally small increments, then the simulation crashes. Not sure what phenomena is going on here. Here's the last log entry: Code:
diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 smoothSolver: Solving for Ux, Initial residual = 1.63336e-16, Final residual = 1.63336e-16, No Iterations 0 smoothSolver: Solving for Uy, Initial residual = 2.63377e-17, Final residual = 2.63377e-17, No Iterations 0 smoothSolver: Solving for Uz, Initial residual = 2.56103e-17, Final residual = 2.56103e-17, No Iterations 0 smoothSolver: Solving for O2, Initial residual = 6.29731e-14, Final residual = 6.29731e-14, No Iterations 0 smoothSolver: Solving for H2O, Initial residual = 6.8088e-14, Final residual = 6.8088e-14, No Iterations 0 smoothSolver: Solving for CO2, Initial residual = 2.01932e-20, Final residual = 2.01932e-20, No Iterations 0 smoothSolver: Solving for H2S, Initial residual = 2.14111e-20, Final residual = 2.14111e-20, No Iterations 0 smoothSolver: Solving for h, Initial residual = 3.94866e-16, Final residual = 3.94866e-16, No Iterations 0 min/max(T) = 237.675, 1102.75 DICPCG: Solving for p, Initial residual = 2.40778e-15, Final residual = 2.40778e-15, No Iterations 0 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 1.04371e-07, global = -4.49885e-09, cumulative = -4.31315e-05 DICPCG: Solving for p, Initial residual = 2.40778e-15, Final residual = 2.40778e-15, No Iterations 0 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 1.04371e-07, global = -4.49885e-09, cumulative = -4.3136e-05 DICPCG: Solving for p, Initial residual = 2.40778e-15, Final residual = 2.40778e-15, No Iterations 0 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 1.04371e-07, global = -4.49885e-09, cumulative = -4.31405e-05 smoothSolver: Solving for omega, Initial residual = 2.97292e-19, Final residual = 2.97292e-19, No Iterations 0 smoothSolver: Solving for k, Initial residual = 1.84934e-18, Final residual = 1.84934e-18, No Iterations 0 ExecutionTime = 7202.62 s ClockTime = 7393 s Courant Number mean: 1.20973e-10 max: 1.04921 deltaT = 6.04121e-29 --> FOAM Warning : From function Time::operator++() in file db/Time/Time.C at line 1055 Increased the timePrecision from 647 to 648 to distinguish between timeNames at time 1.1452 Time = 1.145202402849336831280879778205417096614837646484375 p { margin-bottom: 0.1in; line-height: 120%; } The ground (Bottom patch) is a wall, as is Stack, with a circular inletOutlet velocity patch (Sides). The Top is slip boundary condition. There is another inlet (Inlet) at the top of the stack where the chemicals are injected into the flow domain. Here are the U & p bc's: U Code:
dimensions [0 1 -1 0 0 0 0]; internalField uniform (20 0 0); boundaryField { inlet { type fixedValue; value uniform (0 0 8.4); } bottom { type fixedValue; value uniform (0 0 0); } sides { type inletOutlet; inletValue uniform (20 0 0); value uniform (20 0 0); } stack { type fixedValue; value uniform (0 0 0); } top { type slip; } } Code:
dimensions [1 -1 -2 0 0 0 0]; internalField uniform 1e5; boundaryField { inlet { type zeroGradient; } bottom { type zeroGradient; } sides { type totalPressure; U U; phi phi; rho none; psi none; gamma 1.4; p0 uniform 1e5; } stack { type zeroGradient; } top { type slip; } } Code:
solvers { p { solver PCG; preconditioner DIC; tolerance 1e-7; relTol 0.01; } pFinal { $p; tolerance 1e-7; relTol 0.0; } "(rho|U|h|k|omega)" { solver smoothSolver; smoother symGaussSeidel; tolerance 1e-06; relTol 0.1; } "(rho|U|h|k|omega)Final" { $U; tolerance 1e-7; relTol 0; } Yi { $hFinal; } } PIMPLE { momentumPredictor yes; nOuterCorrectors 1; nCorrectors 3; nNonOrthogonalCorrectors 0; } relaxationFactors { fields { "p.*" 0.3; "rho.*" 1; } equations { "(U|h|k||omega).*" 0.7; } } |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 08:38 |
GETVAR Error in Multiband Monte Carlo Radiation Simulation with Directional Source | silvan | CFX | 3 | June 16, 2014 10:49 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 07:28 |
[Netgen] boundary conditions and mesh exporting | vaina74 | OpenFOAM Meshing & Mesh Conversion | 2 | May 27, 2010 10:38 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 05:15 |
