Pressure driven flow issues at the inlet of a pipe
Old   January 30, 2015, 13:26
Smile Pressure driven flow issues at the inlet of a pipe
Richardpluff
CRI_CFD is on a distinguished road
Hi everyone,
I noticed an strange behaviour at the inlet of my domain when a combination of
totalPressure(p)+pressureInletOutletVelocity(U)-----inlet
and
fixedValue(p)+inletOultet(U)------- outlet.
I want to impose pressure in both inlet and outlet patches. Simulation converges using both simpleFoam and rhoSimpleFoam, but when I look at the results I see a strange behaviour of pressure, velocity and wall shear stress fields. Please have a look at the attachments (this is not the best snapped mesh, but this behaviour is always observed, no matter the mesh quality, size or smoothness, so I guess mesh is not the problem here)
Anybody could give me any hint? Mesh is obtained using blockMesh+snappyHexMesh and surfaceCheck utility shows a good mesh stl quality.
I think this should be related with boundary conditions for a pressure driven flow, but I cannot figure out what is happening. I suppose pressure should be uniform at the inlet and velocity profile should vary in the inlet plane.
This fact for example leads to a wrong magnitude and location of maximun wall shear stress, which is very important in my results.
Thanks in advance,
CRI
CRI_CFD is offline   Reply With Quote
Old   May 25, 2016, 14:11
Caio Martins Ramos de Oliveira
Caio Martins is on a distinguished road
Were you able to solve your problem?
Caio Martins is offline   Reply With Quote
mass flow inlet and pressure outlet with target mass flow rate Zigainer FLUENT 13 October 26, 2018 06:58
Tutorial about pressure inlet, pressure outletReverse flow in pressure inlet Tanjina FLUENT 0 February 26, 2014 01:13
Why we normally provide velocity at inlet and pressure at outlet for pipe flow? p07ip705 Main CFD Forum 3 August 3, 2012 06:53
Pulsatile pressure inlet with pressure outlet a.lynchy FLUENT 3 March 23, 2012 14:45
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
