How to set boundary conditions (U and p) for a bend pipe? |
January 26, 2015, 19:44 |
Adam
Hello, I'm trying to run the flow simulation from this tutorial http://spoken-tutorial.org/watch/Ope...nFOAM/English/, but I can't set the boundary conditions (U and p).
There is the code (the same for velocity and pressure): Code:
17 dimensions [0 2 -2 0 0 0 0]; 18 19 internalField uniform 0; 20 21 boundaryField 22 { 23 inlet 24 { 25 ???? ??????????; 26 } 27 28 outlet 29 { 30 ???? ???????????; 31 } 32 33 walls 34 { 35 ???? ?????; 36 } 37 } 38 39 // ************************************************************************* // Very sorry for my bad english. |
January 27, 2015, 04:56 |
#2 | |
Pratik Nanavati
Rep Power: 12 |
hello, you may try this combination for p and U /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volVectorField; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // // unit of velocity is m/sec dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { inlet { type fixedValue; value uniform (1 0 0); } Wall { type fixedValue; value uniform (0 0 0); } outlet { // Neumann boundary condition. type zeroGradient; } } and /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -2 0 0 0 0]; internalField uniform 0; boundaryField { "(inlet|Wall)" { type zeroGradient; } outlet { // Dirichlet boundary condition. type fixedValue; value uniform 0; } } |
January 27, 2015, 05:43 |
Adam
It's not working. The icoFoam solver has an error: Cannot find patchField entry for outlet.
On previous p and U settings it's work, but when I run the visualization in ParaView nothing happens. This are the configurations codes for p and U on which icoFoam runs without an error. Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -2 0 0 0 0]; internalField uniform 0; boundaryField { inlet { type fixedValue; value uniform 0.02; } outlet { type fixedValue; value uniform 0; } walls { type zeroGradient; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volVectorField; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { inlet { type pressureInletVelocity; value uniform (0 0 0); } outlet { type zeroGradient; } walls { type fixedValue; value uniform (0 0 0); } } // ************************************************************************* // |
Setting rotating frame of referece. | RPFigueiredo | CFX | 3 | October 28, 2014 05:59 |
Overflow Error in Multiphase Modelling with Two Continuous Fluids | ashtonJ | CFX | 6 | August 11, 2014 15:32 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 10:11 |
Pipe Flow Boundary conditions | Kunal Jain | Main CFD Forum | 0 | September 4, 2001 21:52 |
A problem about setting boundary conditions | lyang | Main CFD Forum | 0 | September 19, 1999 19:29 |
