Error when accessing Cp with swakThermoTurbFunctionPlugin
Old   January 22, 2015, 13:25
Default Error when accessing Cp with swakThermoTurbFunctionPlugin
Alex
zfaraday will become famous soon enough
Dear foamers,
I have a little problem with the swakThermoTurbFunctionPlugin. I am using OF 2.3.x and chtMultiRegionFoam solver. My intention is to use the Cp value from the thermophysicalProperties file from a solid region for further calculations using swak4foam. So as to access its value I thought about using swakThermoTurbFunctionPlugin. This is my definition in controlDict:
functions
    thermo_Cp
        type            expressionField;
        region          fasana;
        fieldName       Cp;
        expression      "thermo_Cp()";
        autowrite       true;
libs (
    "libgroovyBC.so"
    "libsimpleFunctionObjects.so"
    "libsimpleSwakFunctionObjects.so"
    "libswakFunctionObjects.so"
    "libgroovyStandardBCs.so"
    "libswakThermoTurbFunctionPlugin.so"
I guess that this is the correct call to the Cp value from the solid region... However, when I run the solver I get this error message:
--> FOAM FATAL IO ERROR:
Attempt to return dictionary entry as a primitive
file: /home/cfd/OpenFOAM/cfd-2.3.x/run/PFC/Alternativa/Proves/habitacle_senser/proves_field_creation/constant/fasana/thermophysicalProperties.thermoType from line 19 to line 25.
    From function ITstream& primitiveEntry::stream() const
    in file db/dictionary/dictionaryEntry/dictionaryEntry.C at line 83.
FOAM aborting
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::IOerror::abort() at ??:?
#2  Foam::dictionaryEntry::stream() const at ??:?
#3  Foam::swakThermophysicalPluginFunction::thermoInternal(Foam::fvMesh const&) at ??:?
#4  Foam::swakThermophysicalPluginFunction_Cp::doEvaluation() at ??:?
#5  Foam::CommonPluginFunction::evaluateInternal(Foam::string const&, int&) at ??:?
#6  Foam::autoPtr<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::FieldValueExpressionDriver::evaluatePluginFunction<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> >(Foam::word const&, parserField::location const&, int&) at ??:?
#7  parserField::FieldValueExpressionParser::parse() at ??:?
#8  Foam::FieldValueExpressionDriver::parseInternal(int) at ??:?
#9  Foam::CommonValueExpressionDriver::parse(Foam::exprString const&, Foam::word const&) at ??:?
#10  Foam::expressionField::write() at ??:?
#11  Foam::expressionField::expressionField(Foam::word const&, Foam::objectRegistry const&, Foam::dictionary const&, bool) at ??:?
#12  Foam::OutputFilterFunctionObject<Foam::expressionField>::allocateFilter() at ??:?
#13  Foam::OutputFilterFunctionObject<Foam::expressionField>::start() at ??:?
#14  Foam::functionObjectList::read() at ??:?
#15  Foam::Time::run() const at ??:?
#16
 at ??:?
#17  __libc_start_main in "/lib64/libc.so.6"
#18
 at /home/abuild/rpmbuild/BUILD/glibc-2.17/csu/../sysdeps/x86_64/start.S:126
I don't know what exactly means "Attempt to return dictionary entry as a primitive" so I don't know what to do next. The only think I did was to check the thermophysicalProperties file from the solid region to check lines 19-25 and these are the referredlines:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      thermophysicalProperties;
thermoType
    type            heSolidThermo;
    mixture         pureMixture;
    transport       constIso;
    thermo          hConst;
    equationOfState rhoConst;
    specie          specie;
    energy          sensibleEnthalpy;
mixture
    specie
        nMoles      1;
        molWeight   50;
    transport
        kappa   0.5;
    thermodynamics
        Hf      0;
        Cp      50;
    equationOfState
        rho     3000;
What's the problem? Am I doing something wrong or is there another way to evaluate this term?
Many thanks for any help you can give me.
Regards,
Alex
Web site where I present my Master's Thesis: foamingtime.wordpress.com
The case I talk about in this site was solved with chtMultiRegionSimpleFoam solver and involves radiation. Some basic tutorials are also resolved step by step in the web. If you are interested in these matters, you are invited to come in!
zfaraday is offline   Reply With Quote
Old   February 10, 2015, 18:31
Alex
No answers untill now for this little problem? Did anyone experience this before?
Thanks
cht solid properties, chtmultiregion, swak4foam, swakexpression, thermoturbfunctionplugin
Help! Having problem in accessing volume fraction gradient Geng Fu Fluent UDF and Scheme Programming 13 April 29, 2020 11:29
Why does accessing a zeroGradient patch return (0 0 0) for a volVectorField l_r_mcglashan OpenFOAM 0 August 20, 2010 14:27
macro for accessing particle thermal conductivity yingying Fluent UDF and Scheme Programming 3 July 15, 2010 05:34
Accessing node values using a UDF Nico FLUENT 2 December 20, 2007 03:50
How to define a Macro accessing rad intensity Grey FLUENT 0 May 21, 2007 01:12
