Freezer simulation
Old   January 20, 2015, 06:20
Default Freezer simulation
jhv_1729's Avatar
Harshad Joshi
jhv_1729 is on a distinguished road
I am trying to simulate the performance of a freezer. The set point of the freezer is -30C. There are some products which will be delivered into the freezer at about 20C. There are a few heat flux boundaries also in the mix. the highest velocities seen will be around 7-8m/s.
Which would be a better solver for this setup:
1) buoyantSimpleFoam (Perfect Gas)
2) buoyantSimpleFoam (incompressible Perfect Gas) or
2) buoyantBoussinesqSimpleFoam?
Cheers,
JHV
jhv_1729 is offline   Reply With Quote
Old   January 21, 2015, 07:42
Tom Fahner
tomf will become famous soon enoughtomf will become famous soon enough
Send a message via MSN to tomf Send a message via Skype™ to tomf
I would go for option 1 in this case. You will have temperature differences of 50 K, around 268 K, which means that your differences are approximately 20 % of the mean temperature. This seems to be a bit too much for the linearized Boussinesq type equation of state.
Regards,
Tom
tomf is offline   Reply With Quote
Waterbell Simulation o.b.m Fluent Multiphase 1 November 5, 2015 06:55
setting up a simulation with multiple interactions phandy OpenFOAM Running, Solving & CFD 1 October 6, 2014 04:16
mass flow rate issue in supersonic nozzle simulation xkang FLUENT 0 July 31, 2014 17:06
Simulation of a complex wing in solidworks flow simulation niels1900 FloEFD, FloWorks & FloTHERM 6 April 20, 2011 11:44
Continuous vs interrupted simulation sega OpenFOAM Running, Solving & CFD 4 November 3, 2008 15:29
