Impinging Jet with v2f model
Old   January 16, 2015, 22:16
Default Impinging Jet with v2f model
anas
anasz is on a distinguished road
Hallo Guys,
I am simulation an impinging jet case using the v2f model. I want to validate the velocity distribution with Ercoftac experimental results. The obtained velocity distribution doesn't match the experimental one (there is no spreading of the velocity normal to the impinged wall) opposite to the low Reynolds number model which have higher spreading width than the experimental one. In the v2d model I am using very fine mesh, and I don't use wall functions.
Any idea is very much welcome!.
anasz is offline   Reply With Quote
Old   January 17, 2015, 09:31
anonymous
ssss is on a distinguished road
Which is your mesh resolution? Reynold Number? Bounday Conditions and turbulence? You will need to give us more information
ssss is offline   Reply With Quote
Old   January 20, 2015, 14:43
Default Settings
anas
Many thanks for the reply.
-The mesh is fine enough. yPlus ~1 or less.
-Re= 23000.
-Boundary conditions:
Wall Boundary conditions:
k = kLowReWallFunction
epsilon = epsilonLowReWallFunction
v2 = v2WallFunction
f = fWallFunction
Inlet values:
v2 = 2/3 k
f = zero-gradient
Other BCs are inletOutlet.
Old   October 19, 2015, 17:29
Mikko
Flowkersma is on a distinguished road
Could you improve your simulation? I'm trying to do exactly the same but I'm getting too high turbulence kinetic energy close to the stagnation region.
Regards,
Mikko
Flowkersma is offline   Reply With Quote
Impinging Jet Boundary Condition Problem mattyg101 FLUENT 7 April 22, 2017 13:52
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 15:32
Slot jet impinging on cylinder Diz CFX 0 September 24, 2007 22:34
V2F - Turbulence Model Computational Dynamics Siemens 3 April 13, 2001 12:49
