Floating point exception (core dumped), running a new solver
Old   January 13, 2015, 20:24
Default Floating point exception (core dumped), running a new solver
anonymous
Mahyar Javidi is on a distinguished road
Hi everybody
I am running a new solver that I developed based on interFoam by adding a new field (volume fraction) to it and using a new viscosity model. It workes up to a certain time then I get this error: Floating point exception
I tried to change the solvers in fvSolution and schems in fvSchemes but no thing really changed.
I just copy/paste the last part that I get from solving a case by this solver, which may help to get a clue.
MULES: Solving for alpha1
Phase-1 volume fraction = 0.516683 Min(alpha1) = -6.43313e-18 Max(alpha1) = 1.1454
Phase-1 volume fraction = 0.516631 Min(alpha1) = -1.54198e-21 Max(alpha1) = 1.1454
DICPCG: Solving for p_rgh, Initial residual = 0.00254906, Final residual = 8.62831e-05, No Iterations 3
time step continuity errors : sum local = 8.62297e-05, global = -2.64316e-08, cumulative = -2.53353e-05
DICPCG: Solving for p_rgh, Initial residual = 0.00031195, Final residual = 1.17906e-05, No Iterations 28
time step continuity errors : sum local = 1.61631e-05, global = 1.28852e-06, cumulative = -2.40467e-05
DICPCG: Solving for p_rgh, Initial residual = 0.000107948, Final residual = 9.00722e-09, No Iterations 82
time step continuity errors : sum local = 1.41569e-08, global = 1.41857e-09, cumulative = -2.40453e-05
GAMG: Solving for Qhi, Initial residual = 0.00241765, Final residual = 8.19049e-05, No Iterations 1
ExecutionTime = 87.7 s ClockTime = 89 s
Courant Number mean: 0.0534621 max: 0.428816
Interface Courant Number mean: 0.00291851 max: 0.357529
deltaT = 0.000111111
Time = 0.00222222
#0 Foam::error:rintStack(Foam::Ostream&) in "/home/mahyar/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigFpe::sigHandler(int) in "/home/mahyar/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2 in "/lib/x86_64-linux-gnu/libc.so.6"
#3 in "/lib/x86_64-linux-gnu/libm.so.6"
#4 Foam:ow(Foam::Field<double>&, Foam::UList<double> const&, double const&) in "/home/mahyar/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#5 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam:ow<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<doub le, Foam::fvPatchField, Foam::volMesh> > const&, Foam::dimensioned<double> const&) in "/home/mahyar/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libincompressibleTransportModels.so"
#6 Foam::viscosityModels:articleVolumFraction::calc Nu() const in "/home/mahyar/OpenFOAM/mahyar-2.1.x/platforms/linux64GccDPOpt/lib/libuserparticleVolumFraction.so"
#7 Foam::viscosityModels:articleVolumFraction::corr ect() in "/home/mahyar/OpenFOAM/mahyar-2.1.x/platforms/linux64GccDPOpt/lib/libuserparticleVolumFraction.so"
#8 Foam::twoPhaseMixture::calcNu() in "/home/mahyar/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libincompressibleTransportModels.so"
in "/home/mahyar/OpenFOAM/mahyar-2.1.x/platforms/linux64GccDPOpt/bin/interFoamParticle"
#10 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#11
I would appreciate any help
Mahyar
Mahyar Javidi is offline   Reply With Quote
Old   January 14, 2015, 08:55
anonymous
ssss is on a distinguished road
So as you can see in the log, there is an error in the calcNu() function, when you call pow(). Try searching in your code if there can be a divition by zero or if there is a sqrt which can be imaginary
ssss is offline   Reply With Quote
Old   January 14, 2015, 11:34
anonymous
Thanks for the reply. I will check the code and let you know what was the issue.
Regards
Mahyar
Old   January 15, 2015, 22:19
anonymous
Hi
The problem was division by the zero. Solver is running perfectly now. Thanks for the help.
Mahyar
Old   January 16, 2015, 03:52
anonymous
You are welcome
Old   August 4, 2015, 05:01
Ipos
Kittipos is on a distinguished road
Hi
I used rhoPorousSimpleFoam to running simple case but it has an error
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam221/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam221/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #2 Uninterpreted: #3 Foam::heRhoThermo<Foam::rhoThermo, Foam:ureMixture<Foam::sutherlandTransport<Foam:: species::thermo<Foam::hConstThermo<Foam:erfectGa s<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::calculate() in "/opt/openfoam221/platforms/linuxGccDPOpt/lib/libfluidThermophysicalModels.so" #4 Foam::heRhoThermo<Foam::rhoThermo, Foam:ureMixture<Foam::sutherlandTransport<Foam:: species::thermo<Foam::hConstThermo<Foam:erfectGa s<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::correct() in "/opt/openfoam221/platforms/linuxGccDPOpt/lib/libfluidThermophysicalModels.so" #5 in "/opt/openfoam221/platforms/linuxGccDPOpt/bin/rhoPorousSimpleFoam" #6 __libc_start_main in "/lib/i386-linux-gnu/libc.so.6" #7 in "/opt/openfoam221/platforms/linuxGccDPOpt/bin/rhoPorousSimpleFoam" Floating point exception (core dumped)
Could you explain me pls
Kittipos is offline   Reply With Quote
Old   April 7, 2018, 13:43
Luís Tiago Ferreira Fernandes
ltiago94 is on a distinguished road
Hello everyone,
How do you think I can find if in my case it is dividing by zero?
I'm using interFoam and when I run it, immediatly I get this error.
Do you know how to solve it?
Thanks
Luís
ltiago94 is offline   Reply With Quote
Floating Point Exception Error nyox FLUENT 11 November 30, 2018 13:31
solving a conduction problem in FLUENT using UDF Avin2407 Fluent UDF and Scheme Programming 1 March 13, 2015 03:02
floating point exception Error AmirBaqa1987 OpenFOAM 1 October 10, 2013 02:29
interDyMFoam- Floating point exception Error marhamat OpenFOAM Running, Solving & CFD 2 December 26, 2012 14:40
[Gmsh] Gmsh and samplesurface touf OpenFOAM Meshing & Mesh Conversion 2 December 10, 2007 03:27
