SimpleFoam Error
Old   January 13, 2015, 17:52
Post SimpleFoam Error
Flexi1095 is on a distinguished road
Hi everyone,
I'm currently working on a calculation with OpenFoam and have a problem with simpleFoam.
First of all I have to say that I'm only 19 years and started working with OF half a year ago. In the beginning I got some help, but most of it I have learned on my own (mainly because it really makes fun ). So I'm not extreme high experienced.^^ But during the time, the work with OF works quite well.
At the time I'm trying to simulate a litte car.
"BlockMesh" & "snappyHexMesh -overwrite" worked both without any problems and according to checkMesh the mesh is ok. In addition at the begining I reduce the scale of the imported .stl with
surfaceTransformPoints AutoWF2014.stl AutoWF2014-m.stl scale '(0.001 0.001 0.001)'
because the CAD program exports in mm.
After doing these steps it looks like this:
https://www.dropbox.com/s/bt3n4x6njz...Bild1.jpg?dl=0
https://www.dropbox.com/s/k65hvf9opy...Bild2.jpg?dl=0
But when I start "simpleFoam", I recive an error right away:
https://www.dropbox.com/s/wonrsug9u6...Bild3.jpg?dl=0
https://www.dropbox.com/s/9g8fgj5i7t...Bild4.jpg?dl=0
https://www.dropbox.com/s/mscaxrcaua...Bild5.jpg?dl=0
Any ideas what I can change? Thank you in advance!
Best regards, Michael
Flexi1095 is offline   Reply With Quote
Old   January 14, 2015, 03:00
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
First of all: If you want to post code, click on the "Go Advanced" button and for code click on the "#"-wrap code button. Put your code / log files between the "CODE" tags. No pictures from suspicious places...
Anyway
It looks like the pressure solver doesn't work. Can you post the fvSolution and fvSchemes files (as I wrote above).
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
Old   January 14, 2015, 06:48
Post
Hi RodriguezFatz,
thanks for your reply.
The fvSolution file looks like this.
|  \\    /   O peration     | Version:  2.2.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSolution;
solvers
    p
        solver          GAMG;
        tolerance       1e-06;
        relTol          0.1;
        smoother        GaussSeidel;
        nPreSweeps      0;
        nPostSweeps     2;
        cacheAgglomeration true;
        nCellsInCoarsestLevel 10;
        agglomerator    faceAreaPair;
        mergeLevels     1;
    U
        solver          smoothSolver;
        nSweeps         2;
        tolerance       1e-08;
        relTol          0.1;
    nuTilda
        nSweeps         2;
        tolerance       1e-08;
        relTol          0.1;
SIMPLE
    nNonOrthogonalCorrectors 0;
//    pRefCell        0;
//    pRefValue       0;
    residualControl
        p               1e-3;
        U               1e-4;
        nuTilda         1e-4;
relaxationFactors
    fields
        p               0.3;
    equations
        U               0.7;
        nuTilda         0.7;
and the fvSchemes.
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSchemes;
ddtSchemes
    default         steadyState;
gradSchemes
    default         Gauss linear;
    grad(p)         Gauss linear;
    grad(U)         Gauss linear;
divSchemes
    default         none;
    div(phi,U)      bounded Gauss linearUpwind grad(U);
    div(phi,nuTilda) bounded Gauss linearUpwind grad(nuTilda);
    div((nuEff*dev(T(grad(U))))) Gauss linear;
laplacianSchemes
    default         none;
    laplacian(nuEff,U) Gauss linear corrected;
    laplacian((1|A(U)),p) Gauss linear corrected;
    laplacian(DnuTildaEff,nuTilda) Gauss linear corrected;
    laplacian(1,p)  Gauss linear corrected;
interpolationSchemes
    default         linear;
    interpolate(U)  linear;
snGradSchemes
    default         corrected;
fluxRequired
    default         no;
    p               ;
Old   January 14, 2015, 06:56
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
Also please post your:
1. checkMesh output
2. Initial and boundary conditions (archive of 0 folder)
As the error happens during solution of pressure equation, you can start by changing GAMG solver to PCG (or play with GAMG settings).
alexeym is offline   Reply With Quote
Old   January 14, 2015, 07:15
Hi alexeym,
1. checkMesh output:
michael@michael-Lenovo-G510:~/OpenFOAM/michael-2.3.0/run/AutoWF2014$ checkMesh
|  \\    /   O peration     | Version:  2.3.0                                 |
Build  : 2.3.0-f5222ca19ce6
Exec   : checkMesh
Date   : Jan 14 2015
Time   : 12:08:31
Host   : "michael-Lenovo-G510"
PID    : 4300
Case   : /home/michael/OpenFOAM/michael-2.3.0/run/AutoWF2014
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create polyMesh for time = 0
Time = 0
Mesh stats
    faces:            873257
    internal faces:   808366
    cells:            270441
    faces per cell:   6.21808
    boundary patches: 7
    point zones:      0
    face zones:       0
    cell zones:       0
Overall number of cells of each type:
    hexahedra:     240837
    prisms:        5194
    wedges:        13
    pyramids:      0
    tet wedges:    104
    tetrahedra:    0
    polyhedra:     24293
    Breakdown of polyhedra by number of faces:
        faces   number of cells
            4   841
            5   1398
            6   5988
            7   138
            8   72
            9   11293
           10   27
           11   13
           12   2772
           14   9
           15   1497
           17   1
           18   241
           21   3
Checking topology...
    Boundary definition OK.
    Cell to face addressing OK.
    Point usage OK.
    Upper triangular ordering OK.
    Face vertices OK.
   *Number of regions: 9
    The mesh has multiple regions which are not connected by any face.
  <<Writing region information to "0/cellToRegion"
  <<Writing region 0 with 270433 cells to cellSet region0
  <<Writing region 1 with 1 cells to cellSet region1
  <<Writing region 2 with 1 cells to cellSet region2
  <<Writing region 3 with 1 cells to cellSet region3
  <<Writing region 4 with 1 cells to cellSet region4
  <<Writing region 5 with 1 cells to cellSet region5
  <<Writing region 6 with 1 cells to cellSet region6
  <<Writing region 7 with 1 cells to cellSet region7
  <<Writing region 8 with 1 cells to cellSet region8
Checking patch topology for multiply connected surfaces...
                   Patch    Faces   Points                  Surface topology
                   inlet      225      256  ok (non-closed singly connected)
                  outlet      225      256  ok (non-closed singly connected)
                    left     8619     9630  ok (non-closed singly connected)
                   right     1125     1216  ok (non-closed singly connected)
                   floor     7641     8119  ok (non-closed singly connected)
                    roof     1125     1216  ok (non-closed singly connected)
                fahrzeug    45931    48597  ok (non-closed singly connected)
Checking geometry...
    Overall domain bounding box (-1 0 -0.0055) (0.5 0.3 0.3)
    Mesh (non-empty, non-wedge) directions (1 1 1)
    Mesh (non-empty) directions (1 1 1)
    Boundary openness (3.20843e-16 -1.31603e-14 5.93089e-15) OK.
    Max cell openness = 3.37423e-16 OK.
    Max aspect ratio = 20.9569 OK.
    Minimum face area = 6.90304e-09. Maximum face area = 0.00040934.  Face area magnitudes OK.
    Min volume = 8.46529e-13. Max volume = 8.1737e-06.  Total volume = 0.137385.  Cell volumes OK.
    Mesh non-orthogonality Max: 55.9442 average: 9.03408
    Non-orthogonality check OK.
    Face pyramids OK.
    Max skewness = 2.4256 OK.
    Coupled point location match (average 0) OK.
Mesh OK.
End
[1]+  Exit 1                  paraFoam
2. Files in 0 folder (exept cellToRegion):
- nut:
|  \\    /   O peration     | Version:  1.6                                   |
|   \\  /    A nd           | Web:      http://www.OpenFOAM.org               |
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      nut;
dimensions      [0 2 -1 0 0 0 0];
internalField   uniform 0.006;
boundaryField
    inlet
        type            fixedValue;
        value           $internalField;
    outlet
        type            zeroGradient;
    right
        type            slip;
    left
        type            symmetryPlane;
    floor
        type            slip;
    roof
        type            slip;
    "fahrzeug.*"
        type            nutUSpaldingWallFunction;
        value           uniform 0;
- nuTilda:
FoamFile
    version     2.0;
    format      ascii;
    object      nuTilda;
internalField   uniform 0.011;
boundaryField
    inlet
        type            fixedValue;
    outlet
        type            zeroGradient;
    right
        type            slip;
    left
        type            symmetryPlane;
    floor
        type            slip;
    roof
        type            slip;
    "fahrzeug.*"
        type            zeroGradient;
- p:
FoamFile
    version     2.0;
    format      ascii;
    object      p;
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 0;
boundaryField
    inlet
        type            zeroGradient;
    outlet
        type            fixedValue;
    right
        type            slip;
    left
        type            symmetryPlane;
    floor
        type            slip;
    roof
        type            slip;
    "fahrzeug.*"
        type            zeroGradient;
- U:
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (-33.333 0 0);
boundaryField
    inlet
        type            fixedValue;
    outlet
        type            zeroGradient;
    right
        type            slip;
    left
        type            symmetryPlane;
    floor
        type            slip;
    roof
        type            slip;
    "fahrzeug.*"
        type            fixedValue;
        value           uniform (0 0 0);
Old   January 14, 2015, 07:46
Philipp
Ok, can you try:
p
        solver           GAMG;
        tolerance        1e-12;
        relTol           0.1;
        maxIter         20;
        smoother         DIC;
        nPreSweeps       1;
        nPostSweeps      1;
        nFinestSweeps    2;
        nCellsInCoarsestLevel 1000;
        mergeLevels      1;
Why do you use an old version of openFOAM? Edit: Ok, it's just the file...
Old   January 14, 2015, 08:58
Post
Hi RodriguezFatz,
thanks for your help, but I still get an error.
michael@michael-Lenovo-G510:~/OpenFOAM/michael-2.3.0/run/AutoWF2014$ simpleFoam
Exec   : simpleFoam
Date   : Jan 14 2015
Time   : 13:45:09
PID    : 6967
nProcs : 1
Create time
Create mesh for time = 0
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting RAS turbulence model SpalartAllmaras
SpalartAllmarasCoeffs
    sigmaNut        0.66666;
    kappa           0.41;
    Cb1             0.1355;
    Cb2             0.622;
    Cw2             0.3;
    Cw3             2;
    Cv1             7.1;
    Cv2             5;
    Employing Ashford correction
No finite volume options present
SIMPLE: convergence criteria
    field p	 tolerance 0.001
    field U	 tolerance 0.0001
    field nuTilda	 tolerance 0.0001
Starting time loop
Time = 1
smoothSolver:  Solving for Ux, Initial residual = 1, Final residual = 0.0330649, No Iterations 4
smoothSolver:  Solving for Uy, Initial residual = 1, Final residual = 0.0883086, No Iterations 2
smoothSolver:  Solving for Uz, Initial residual = 1, Final residual = 0.0976873, No Iterations 2
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigFpe::sigHandler(int) at ??:?
#2   in "/lib/x86_64-linux-gnu/libc.so.6"
#3  Foam::DICPreconditioner::calcReciprocalD(Foam::Field<double>&, Foam::lduMatrix const&) at ??:?
#4  Foam::DICSmoother::DICSmoother(Foam::word const&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&) at ??:?
#5  Foam::lduMatrix::smoother::addsymMatrixConstructorToTable<Foam::DICSmoother>::New(Foam::word const&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&) at ??:?
#6  Foam::lduMatrix::smoother::New(Foam::word const&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::dictionary const&) at ??:?
#7  Foam::GAMGSolver::initVcycle(Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::lduMatrix::smoother>&, Foam::Field<double>&, Foam::Field<double>&) const at ??:?
#8  Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
#9  Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) at ??:?
#10  Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:?
#11
 at ??:?
#12
 at ??:?
#13  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#14
 at ??:?
Gleitkomma-Ausnahme (Speicherabzug geschrieben)
I use OpenFoam 2.3.0. I know that 2.3.1 was published in December, but had no time to install the new version. Are there so many advantages that I should do it immediately?
Old   January 14, 2015, 09:16
Alexey Matveichev
as GAMG fails try PCG, i.e.
    p
        solver          PCG;
        preconditioner  DIC;
        tolerance       1e-8;
        relTol          1e-2;
Also you've got 55 degree of maximum non-orthogonality, increase number of nNonOrthogonalCorrectors, start with 1-2.
Old   January 14, 2015, 16:07
Post
Hi alexeym,
thanks for your idea with PCG, but the error occures at the same time.
Also to increase the numbers of nNonOrthogonalCorrectors doesn't helps.
Another idea: Could the error come from the possibility that the stl file has somewhere a little hole and is not completely closed?
Old   January 15, 2015, 02:57
Philipp
Flexi, checkMesh says that mesh openness is not a problem...
But what does that mean:
Can you post a picture of your domain?
Old   January 15, 2015, 03:00
Vojtech Betak
betakv is on a distinguished road
Dear Flexi1095,
the error is in your mesh. You have there a 8 regions with 1 cell. Please try to create another mesh.
VB
betakv is offline   Reply With Quote
Old   January 15, 2015, 16:57
Post
  #12
Hi RodriguezFatz & betakv,
@RodriguezFatz: see attachment
So if I understand correctly, the problem comes with snappyHexMesh, which creates the 8 regions with only 1 cell. I have repeated the same process, but there are again these 9 regions.
Do you have an ideas what could cause this problem?
Thanks for your help so far!
Old   July 10, 2017, 05:46
hokhay is on a distinguished road
Hi Rodriguez,
Have you managed to find a solution for this problem?
Sorry to bring this post back. I am now facing the exact same problem with you. I have posted the problem in the forum for 2 weeks but with no single response. It seems the problem has been here for more than at least 2 years but no one has seems to know why.
Could anyone help me with this problem please?
Jason
hokhay is offline   Reply With Quote
simplefoam, solver error
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 10:00
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 10:17
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." sega OpenFOAM Community Contributions 12 February 17, 2010 10:30
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 03:32
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
