Using wallheatflux to calculate heat fluxes on cylinder
Old   January 10, 2015, 09:26
Exclamation Using wallheatflux to calculate heat fluxes on cylinder
Le0nid is on a distinguished road
Hi everyone
I am trying to simulate a 2D hypersonic flow around cylinder (using rhoCentralFoam) based on the experimental data presented in “STUDIES OF AEROTHERMAL LOADS GENERATED IN REGIONS OF SHOCK/SHOCK INTERACTION IN HYPERSONIC FLOW” paper (Run 40).
Although excellent agreement with experimental data in terms of wall pressure was obtained, the wall heat flux values (calculated using wallheatflux utility) turned out to be 1.5 times smaller. This is a large error considering the fact that the boundary layer was laminar in the experiment.
Anybody had similar problems with wallheatflux?
Calorically perfect air with viscosity described by Sutherland's law and Pr=0.72 was used.
EDIT: problem is solved.
Le0nid is offline   Reply With Quote
Local heat transfer / modifying wallHeatFlux buck_s OpenFOAM Programming & Development 0 June 17, 2014 06:54
Local heat transfer / modifying wallHeatFlux buck_s OpenFOAM Post-Processing 0 June 17, 2014 06:52
How to calculate heat transfer for two different velocity fields? eneja Fluent UDF and Scheme Programming 0 June 10, 2014 02:52
Calculate Heat Flux (Radiative/Conductive/Convective) m_f OpenFOAM Post-Processing 0 September 3, 2012 04:16
Heating of a solid cylinder with internal heat generation Sriram Popuri Main CFD Forum 6 July 13, 1999 18:09
