channel flow simulation
Old   January 9, 2015, 12:02
Default channel flow simulation
Gian Patrizio
GPDZ is on a distinguished road
hi all,
I am new in this forum and I am a new user of OpenFoam. I have to study a isentropic, adiabatic subsonic flow in a tube convergent-divergent, given an inlet pressure and outlet pressure.
I have already done the mesh with gmesh. the problem is that I don't know which solver to use and if the mesh is correct.
please if somebody has already done this could explain it to me ??
i know it's a really trivial problem for those who deal with OF daily so I'm sure you can help me out in few seconds just telling me what to do.
many thanks in advance.
GP
GPDZ is offline   Reply With Quote
Old   January 12, 2015, 08:34
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
Hey,
Is this steady-state, uncompressible and turbulent?
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
Old   January 14, 2015, 06:48
Gian Patrizio
yes it is. really simple I guess, but for me it is not!
Old   January 14, 2015, 07:43
Philipp
You can find a list of solvers here:
http://www.openfoam.org/features/standard-solvers.php
With the things you wrote here, you could use simpleFOAM.
Old   January 14, 2015, 08:06
Gian Patrizio
ok thanx, but what shall i do to use simplefoam?
Old   January 14, 2015, 08:09
Philipp
You can find some examples how to configure the solver in the tutorial folder (OpenFOAM.../turotirals/incompressible/simpleFOAM).
I guess you need to read and try a bit with those tutorials and then ask some more explicit questions about the problems you face.
Old   January 14, 2015, 11:19
Gian Patrizio
i have tried to run the tutorial of simplefoam but when i digit blockmesh it says that the foam fails because in the controldict it is referred to an external library!! I have no idea of how to handle this!!
Old   January 14, 2015, 11:23
Philipp
Which tutorial?
Old   January 15, 2015, 05:36
Gian Patrizio
Which tutorial?
pipeCyclic
Old   January 15, 2015, 05:40
Philipp
Don't you have an "Allrun" script in the tutorial? You can just start that, or have a look inside for the missing command.
Old   January 15, 2015, 06:57
Gian Patrizio
this is the allrun script.yet, i don't know how to run it and what does it do?
thank you very much for your patience and kindness
Old   January 15, 2015, 06:59
Gian Patrizio
#!/bin/sh
cd ${0%/*} || exit 1 # run from this directory
# Source tutorial run functions
. $WM_PROJECT_DIR/bin/tools/RunFunctions
# Get application directory
application=`getApplication`
# This case uses the #codeStream which is disabled by default. Enable for
# just this case.
MAIN_CONTROL_DICT=`foamEtcFile controlDict`
if [ -f "$MAIN_CONTROL_DICT" ]
then
echo "Modifying ${MAIN_CONTROL_DICT} to enable allowSystemOperations"
# Clean up on termination and on Ctrl-C
trap 'mv ${MAIN_CONTROL_DICT}.$$ ${MAIN_CONTROL_DICT} 2>/dev/null; exit 0' \
EXIT TERM INT
cp ${MAIN_CONTROL_DICT} ${MAIN_CONTROL_DICT}.$$
echo "Enabling allowSystemOperations in ${MAIN_CONTROL_DICT}."
sed \
-e s/"\(allowSystemOperations[ \t]*\)\([0-9]\);"/"\1 1;"/g \
${MAIN_CONTROL_DICT}.$$ > ${MAIN_CONTROL_DICT}
fi
runApplication blockMesh
runApplication topoSet
runApplication refineHexMesh c0 -overwrite
cp -r 0.org 0
#runApplication $application
runApplication decomposePar -cellDist
runParallel $application 5
runApplication reconstructPar
# ----------------------------------------------------------------- end-of-file
Old   January 18, 2015, 06:22
Exclamation solution??
  #13
Gian Patrizio
so... what is the solution? how shall I run an Allrun script? and what does it do? and how do I study the flow in a channel with an already done mesh(I have done a mesh with Gmesh, the shape is a convergent-divergent and I have done 3 boundaries: inlet, outlet and side walls). Please help me out guys!!
Old   January 29, 2015, 06:37
thg
Thorsten Grahs
thg is on a distinguished road
maybe you post your case here?!
you execute the Allrun script with
./Allrun
it makes in pricipal
i) the mesh i.e. runApplication blockMesh
ii) generate some regions/cellSets runApplication topoSet
iii) refines this regions runApplication refineHexMesh c0 -overwrite
iv) copy the inital value folder 0 i.e. cp -r 0.org 0
v) runs the solver in parallel
(the name of the solver is read with getApplication from the
controlDict entry...)
vi) reconstruct the paralel case runApplication reconstructPar
That's it.
thg.
thg is offline   Reply With Quote
adiabatic, channel, convergent-divergent, isentropic, turbolent flow
Boundary condition problem for open channel flow Andy CFX 9 June 11, 2016 08:20
Simulation of a complex wing in solidworks flow simulation niels1900 FloEFD, FloWorks & FloTHERM 6 April 20, 2011 11:44
gas flow out of a C-D channel ljp FLUENT 0 March 7, 2011 15:32
Natural convection - Inlet boundary condition max91 CFX 1 July 29, 2008 21:28
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
