values on a slip boundary
Old   January 9, 2015, 10:20
Default values on a slip boundary
M. Sabouri
Moslem is on a distinguished road
I want to use the slip boundary condition for some domain boundaries in a CFD solution. I need to know the velocity vectors on those boundaries. unfortunately OF does not report them in the data files and specifies the slip boundaries like this:
upperWall
type slip;
lowerWall
type slip;
How can I force the OF to report the velocity vectors ?
Thanks in advance.
p.s. The same problem exists using the symmetryPlane boundary condition.
Moslem is offline   Reply With Quote
Old   January 10, 2015, 04:25
Nima Samkhaniani
nimasam is on a distinguished road
Dear your question is vague, if you want to see velocity vector, you can use parafoam, choose the patch you like
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Old   January 10, 2015, 05:07
M. Sabouri
I want the OF to report the "numerical" values of velocity vectors exactly on the boundary. OF just defines the whole boundary as "slip". I cannot find what is the velocity vector on each face element. I want to present the boundary values, e.g. tangential velocity, on a graph.
Old   January 10, 2015, 05:14
Nima Samkhaniani
So my pervious method, should work for you.
Old   January 10, 2015, 05:33
M. Sabouri
Thanks,
Yes, it works. But, I'm not sure if they are the exact values obtained in the simulation. It seems that the postprocessing softwares (Paraview and Tecplot) calculate these boundary values by some kind of inter/extrapolation methods. As an evidence, this method does not yield zero values for the normal velocity on a slip (or symmetry) boundary.
slip b.c., symmetryplane, write control
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
Boundary face values in density based solver? Chen Zhi FLUENT 3 November 28, 2019 07:51
Difficulty In Setting Boundary Conditions Moinul Haque CFX 4 November 25, 2014 18:30
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
