January 8, 2015, 04:31 |
Urans solution does not "converge"
luca
Rep Power: 11 |
Hi everyone. I'm trying to simulate a 3D sphere in the unsteady case. The steady case converged fine, the field and the coefficients seems to be close enought to the real. Using the same boundary and initial conditions and changing only the fvchemes, fvsolution and controldict (witch i took and manipulate from the motorbike pisofoam tutorial) the solution seem to converge at the beginning but the pressure is oscillating strongly and after 50 iterations the velocities start to diverge and then start oscillating. I tried both starting from initial field of p=0 and U=(1 0 0) and from the resolved stationary case.
Any ideas? Thank you |
January 8, 2015, 05:48 |
Philipp
Rep Power: 27 |
1) What means "the velocities start to diverge and then start oscillating"?
2) Can you post some log output of the "diverging" time steps?
The skeleton ran out of shampoo in the shower. |
January 8, 2015, 06:47 |
luca
Rep Power: 11 |
Hi thank you for your quick reply. I should have specified that the residuals start to diverge. I will link my gnuplot output so you can see what I mean.
I also tried to use the setup from this page http://www.cfd-online.com/Forums/ope...omega-sst.html as his case is quite similar to mine (obviuolsy I changed the empty boundary with mine) the pressure acts in the same way velocities does not diverge but the dt decreases fastly to very small values (1e-6) |
January 8, 2015, 07:11 |
Philipp
Rep Power: 27 |
January 8, 2015, 07:19 |
luca
Rep Power: 11 |
The file is too large for this site so I give you the dropbox link
https://www.dropbox.com/s/q77r6gne8j2lqxt/log.txt?dl=0 |
January 8, 2015, 07:45 |
Philipp
Rep Power: 27 |
1) I would use a fixed time step of 1e-4 with maybe 4 pressure corrections in piso.
2) Did you set laplacian to "Gauss linear corrected"? It looks like that... Try "Gauss linear uncorrected". 3) I would start with "backward" time differencing.
January 8, 2015, 08:01 |
Philipp
Rep Power: 27 |
If you try it... post the log output after some iterations...
January 8, 2015, 08:02 |
luca
Rep Power: 11 |
I tried many different solution that I took from differnt tutorial. I used also backward scheme for time but nothing changed. I also tried the set up from thies page as the case is similar to mine (exept from it is 2D ad I changed the empty BC)
http://www.cfd-online.com/Forums/ope...omega-sst.html I will post the fvchemes and fvsolution. May it be the mesh? I've done it with ansa and it has some non orthogonal faces but running the checkmesh is OK |
January 8, 2015, 08:09 |
#9 |
Philipp
Rep Power: 27 |
Ok, additionally you should change the divScheme to "default Gauss upwind phi;" and delete all of them except the "nuEff*..."
January 8, 2015, 09:41 |
#10 |
Philipp
Rep Power: 27 |
Now, what do you get with these modifications?
Asymmetrical solution using RANS | Marli | FLUENT | 2 | January 9, 2015 10:26 |
grid dependancy | gueynard a. | Main CFD Forum | 19 | June 27, 2014 22:22 |
Analytic solution for 2D steady Euler equations | jojo81 | Main CFD Forum | 0 | October 15, 2012 13:05 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 03:58 |
Wall functions | Abhijit Tilak | Main CFD Forum | 6 | February 5, 1999 02:16 |
