Problems using fvdom radiation model and convection heat transfer
Old   January 7, 2015, 10:08
Default Problems using fvdom radiation model and convection heat transfer
JuNNioR
jrsilvio_ver is on a distinguished road
One test problem was implemented using fvdom radiation model on BuoyantBousinesqPimpleFoam with a domain between two parallel plates. The upper one is hot with T=1000K (fixed temperature) and the bottom one is insulated (zerogradient). Air flow at 300K and V=15 cm/s was imposed on the input between parallel plates.
It was expected that the temperature on the bottom plane was higher than 300K. But it was not verified! The model was attached. I don't understand what is happening... Someone can help me?
jrsilvio_ver is offline   Reply With Quote
Old   January 13, 2015, 13:14
JuNNioR
Nothing????
Old   January 20, 2015, 09:00
Pedro
pedrojrebelo is on a distinguished road
I didntīt had time to check the results but I think one of the problems you have is in the definition of the BC conditions for p and p_rgh. Check the file I attached.
File Type: zip p&p_rgh.zip (994 Bytes, 10 views)
pedrojrebelo is offline   Reply With Quote
Old   January 22, 2015, 14:01
JuNNioR
Pedro, I appreciate your response.
But the problem is the heat exchange by radiation, not in the flow.
Anyway I will test the suggested changes.
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
Comparison of radiation and convection heat transfer panos_metal FLUENT 0 December 5, 2011 22:04
model forced convection heat transfer on a heat sink farzad FLUENT 0 September 9, 2010 15:48
heat transfer with s2s radiation model in fluent D. L. FLUENT 3 July 31, 2008 08:40
Natural convection - Inlet boundary condition max91 CFX 1 July 29, 2008 21:28
