Crash while solving lagrangian cloud
Old   January 7, 2015, 09:52
Default Crash while solving lagrangian cloud
Werner
Polli is on a distinguished road
I use a modified steadycompressibleMRFFoam out of OpenFOAM extend 3.1 and combined it with the coalCombustionCase to fill in the particle movement into the steadycompressibleMRFFoam. The simulation has a problem while solving the particle cloud. It does not crash and stops but the simulation never ends solving the cloud and begins to hang. There is no error message, it only take more than days for one iteration at the particles. Normally it takes 2 seconds to solve the cloud. There are no problem with the flow field, i insert the particles in the stady state flow filed.
I tried many different things, like reducing the timestep, meshing the surface more exactly and things like that.
Do anybody know a possible solution for this problem?
Polli is offline   Reply With Quote
Old   January 8, 2015, 16:49
Chrisi1984 is on a distinguished road
Hi Polly,
are you using "rebound" as wall interaction? In case you do so, the reason might be some bad quality in the mesh near to the wall.
For lagrangian simulations the mesh check should include an additional option:
checkMesh -allGeometry
Check the result from that analysis regarding "face tet" errors. Those "face tet" errors might be the reason for your "endless loop".
Kind regards
Chrisi
Chrisi1984 is offline   Reply With Quote
Old   January 9, 2015, 07:59
Werner
Thank you for your input! I will check this. But one question, in wich line can i see if the face tet is ok or not. In the checkMesh - allGeometry i cant find a output which says face tet ok or not
Old   January 9, 2015, 13:48
this is a part of the output of checkMesh -allGemetry
Checking geometry...
Overall domain bounding box (-0.0992995958 -1.00600017 -0.0992995271) (0.0992943162 0.205000025 0.0992996263)
Mesh (non-empty, non-wedge) directions (1 1 1)
Mesh (non-empty) directions (1 1 1)
Boundary openness (5.29574358e-17 -5.49843007e-17 1.75436041e-16) OK.
Max cell openness = 3.17555515e-16 OK.
Max aspect ratio = 9.68193754 OK.
Minumum face area = 3.52951045e-08. Maximum face area = 2.4132503e-05. Face area magnitudes OK.
Min volume = 6.03259587e-12. Max volume = 7.03459743e-08. Total volume = 0.0126674936. Cell volumes OK.
Mesh non-orthogonality Max: 74.3872277 average: 15.458555
*Number of severely non-orthogonal faces: 1.
Non-orthogonality check OK.
<<Writing 1 non-orthogonal faces to set nonOrthoFaces
Face pyramids OK.
Max skewness = 0.961890176 OK.
Coupled point location match (average 0) OK.
Face tets OK.
Min/max edge length = 0.000193831119 0.00775369872 OK.
All angles in faces OK.
Face flatness (1 = flat, 0 = butterfly) : average = 0.999989587 min = 0.987503483
All face flatness OK.
Cell determinant (wellposedness) : minimum: 0 average: 3.06790921
***Cells with small determinant found, number of cells: 557
<<Writing 557 under-determined cells to set underdeterminedCells
Concave cell check OK.
Failed 1 mesh checks.
There in you can read "Face tets OK".
Can you please check that again for your case.
Old   September 29, 2022, 04:51
geth03 is on a distinguished road
is there any workaround in case that face tets is not ok?
geth03 is offline   Reply With Quote
lagrange, mrf, particle, particle cloud
simpleFoam error - "Floating point exception" mbcx4jc2 OpenFOAM Running, Solving & CFD 12 August 4, 2015 03:20
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
Unstabil Simulation with chtMultiRegionFoam mbay101 OpenFOAM Running, Solving & CFD 13 December 28, 2013 14:12
calculation stops after few time steps sivakumar OpenFOAM Running, Solving & CFD 7 March 17, 2013 07:37
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
