interFoam & interDyMFoam
Old   December 22, 2014, 04:39
Exclamation interFoam & interDyMFoam
Kayhan
ulgenk is on a distinguished road
I am working on a planning hull's resistance prediction using interDyMFoam solver. After some iterations the solution blows up due to the increase of alpha values and the solution diverges immediately. If I use interFoam solver, the solution converges after some time. Why did this happen?
ulgenk is offline   Reply With Quote
Old   January 9, 2015, 08:35
Sebastian W.
nero235 is on a distinguished road
Send a message via ICQ to nero235
Can you supply more information, like the output of checkMesh, the solver log or some post-processing from right before the solver crashes?
Maybe you got bad cells and due to the refinement in that region the solver crashes. It can be anything but if you want precise answers please supply more information.
Regards, Sebastian
nero235 is offline   Reply With Quote
Old   January 28, 2015, 07:50
Kayhan
Regards, Sebastian
I found the issue that was about boundary conditions. I am using kw-SST turbulence model. But when I use the turbulence free stream calculator from this website, omega value was very huge. Then I used some formulization that was implemented by ESI Group. This formulization is using the same epsilon value which can be found using turbulent length scale. Then omega value is found when epsilon is divided by turbulent kinetic energy (k). It is for kw-SST turbulence model, it says.
interdymfoam, interfoam
InterDyMFoam unstable. InterFoam fine. Denao OpenFOAM Running, Solving & CFD 2 May 6, 2016 09:13
Difference between results in interFoam and interDyMFoam erebus OpenFOAM Running, Solving & CFD 0 January 29, 2014 09:31
InterFoam vs InterDyMFoam Rose2011 OpenFOAM 4 March 6, 2013 11:56
error using interDyMFoam with kOmegaSST to simulate sloshing anmartin OpenFOAM Running, Solving & CFD 0 July 20, 2010 14:21
alpha or alpha1 in interFoam & interDyMFoam wavytracy OpenFOAM Bugs 3 September 10, 2009 03:51
