December 19, 2014, 17:32 |
laplacianFoam, floating point exception
Max Kern
I'm a new OpenFoam user and stuck with a problem you might consider rather trivial. I tried to run a simulation very similar to the laplacianFoam (flange) tutorial. controlDict, fvSchemes, transportProperties and fvSolution are the same as in the tutorial. The Mesh was generated with blockMesh Code:
FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 0.001; vertices ( (-5 -5 0) //0 (5 -5 0) //1 (5 5 0) //2 (-5 5 0) //3 (-5 -5 50) //4 (5 -5 50) //5 (5 5 50) //6 (-5 5 50) //7 ); blocks ( hex (0 1 5 4 3 2 6 7) (10 100 10) simpleGrading (1 1 1) //0 ); edges ( ); patches ( patch front ( (0 1 2 3) ) patch back ( (4 5 6 7) ) patch tube ( (0 3 7 4) (3 2 6 7) (1 5 6 2) (0 1 5 4) ) ); Code:
FoamFile { version 2.0; format ascii; class volScalarField; object T; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [ 0 0 0 1 0 0 0 ]; internalField uniform 273; boundaryField { front { type fixedValue; value uniform 273; } tube { type zeroGradient; } back { type fixedValue; value uniform 573; } } // ************************************************************************* // Code:
DICPCG: Solving for T, Initial residual = 0.480419, Final residual = 8.34292e-07, No Iterations 60 #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 in "/lib/x86_64-linux-gnu/libc.so.6" #3 double Foam::sumProd<double>(Foam::UList<double> const&, Foam::UList<double> const&) at ??:? #4 Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? #5 Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) at ??:? #6 Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:? #7 at ??:? #8 at ??:? #9 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #10 at ??:? Floating point exception (core dumped) Thanks, Max |
floating point exception, laplacianfoam |
Floating point exception with pimpleDyMFoam | ebah6 | OpenFOAM Running, Solving & CFD | 9 | November 1, 2017 06:58 |
Inlet Velocity Profile BC - Floating Point exception during solution initialization | Janshi | STAR-CCM+ | 4 | March 14, 2012 11:21 |
simpleFoam Floating point exception error -help | sudhasran | OpenFOAM Running, Solving & CFD | 3 | March 12, 2012 17:23 |
Pipe flow in settlingFoam floating point exception | jochemvandenbosch | OpenFOAM Running, Solving & CFD | 4 | February 16, 2012 04:24 |
block-structured mesh for t-junction | Robert@cfd | ANSYS Meshing & Geometry | 20 | November 11, 2011 05:59 |
