December 19, 2014, 10:39 |
running solver fireFoam on OF2.3.1
Roman
Rep Power: 13 |
Hello all! I tried to run some of my OF cases (solver - fireFoam) for the version 2.2.2 on OF2.3.1 (official version) and found surprisingly different results. On the OF2.2.2 the results of the fire modelling were close to the experimental data. On the OF2.3.1 the same OF-cases run unstable, the velocity fields differ strongly especially near the patches that model the atmosphere and the ventilation, the heat release rate of the fire become higher (with the same massFlowrate of the fuel). On OF2.3.0 all the things were the same as on the OF2.2.2. Is there an explanation of such situation, even e.g. bad gasket between the computer and the chair? Thanks.
thobois class engineTopoChangerMesh error | Peter_600 | OpenFOAM | 4 | August 2, 2014 10:52 |
No running solver after successful installation of OF-2.1.x on SGI Altix UV 1000 | sebastian | OpenFOAM Installation | 16 | November 13, 2012 06:10 |
[PyFoam] Running multiple instances of solver using MPI and PyFoam | bfa | OpenFOAM Community Contributions | 3 | January 25, 2011 18:57 |
Running Problem using Openfoam solver | cfd_staruser | OpenFOAM | 5 | August 14, 2009 03:28 |
problem running the solver | chotet | CFX | 1 | January 17, 2007 04:59 |
