keyword phases is undefined in dictionary - ERROR
Old   December 19, 2014, 07:07
Default keyword phases is undefined in dictionary - ERROR
Nidhin R
Nidhin R is on a distinguished road
Hey,
I am new to OpenFoam and have been rying to eorkout the breakwater tutorials in IHFOAM. when i got the following error
--> FOAM FATAL IO ERROR:
keyword phases is undefined in dictionary "/home/nidhin/OpenFOAM/nidhin-2.3.0/run/breakwater/constant/transportProperties"
file: /home/nidhin/OpenFOAM/nidhin-2.3.0/run/breakwater/constant/transportProperties from line 20 to line 69.
From function dictionary::lookupEntry(const word&, bool, bool) const
in file db/dictionary/dictionary.C at line 437.
FOAM exiting
the transportProperties line 20 to line 69 is as follows:
twoPhase
transportModel twoPhase;
phase1 phase1;
phase2 phase2;
phase1
transportModel Newtonian;
nu nu [ 0 2 -1 0 0 0 0 ] 1e-06;
rho rho [ 1 -3 0 0 0 0 0 ] 1000;
CrossPowerLawCoeffs
nu0 nu0 [ 0 2 -1 0 0 0 0 ] 1e-06;
nuInf nuInf [ 0 2 -1 0 0 0 0 ] 1e-06;
m m [ 0 0 1 0 0 0 0 ] 1;
n n [ 0 0 0 0 0 0 0 ] 0;
BirdCarreauCoeffs
nu0 nu0 [ 0 2 -1 0 0 0 0 ] 0.0142515;
k k [ 0 0 1 0 0 0 0 ] 99.6;
n n [ 0 0 0 0 0 0 0 ] 0.1003;
phase2
nu nu [ 0 2 -1 0 0 0 0 ] 1.48e-05;
rho rho [ 1 -3 0 0 0 0 0 ] 1;
CrossPowerLawCoeffs
BirdCarreauCoeffs
sigma sigma [ 1 0 -2 0 0 0 0 ] 0.07;
can someone suggest whatt need to be done??
Nidhin R is offline   Reply With Quote
Old   December 19, 2014, 07:19
styleworker is on a distinguished road
I'm not familiar with the solver but I think it should be something like
phases (water air);
or
phases (phase1 phase2);
depending on your OF version.
styleworker is offline   Reply With Quote
Old   September 24, 2020, 16:57
Unhappy same kind of error
Deutschland
vava10 is on a distinguished road
hey,
I am newto OpenFoam and I am using OpenFoam v-2006
I am working with wigleyHull case from https://github.com/OpenFOAM/OpenFOAM...oam/wigleyHull
I ran setFields and got the following error
| \\ / O peration | Version: v2006 |
| \\ / A nd | Website: www.openfoam.com |
| \\/ M anipulation | |
Build : _b45f8f6f58-20200629 OPENFOAM=2006
Arch : "LSB;label=32;scalar=64"
Exec : interFoam
Date : Sep 24 2020
Time : 21:45:50
Host : LAPTOP-A0NOGRUJ
PID : 3673
I/O : uncollated
Case : /home/sam/OpenFOAM/OpenFOAM-v2006/tutorials/wigleyHull
nProcs : 1
trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE).
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 5, maxFileModificationPolls 20)
allowSystemOperations : Allowing user-supplied system call operations
Create time
--> FOAM Warning :
From static Foam::IOstreamOption::compressionType Foam::IOstreamOption::compressionEnum(const Foam::word&, Foam::IOstreamOption::compressionType)
in file db/IOstreams/IOstreams/IOstreamOption.C at line 115
Unknown compression specifier 'compressed', using compression off
Create mesh for time = 0
PIMPLE: Operating solver in PISO mode
Using LTS
Reading field p_rgh
Reading field U
Reading transportProperties
--> FOAM FATAL ERROR:
cannot find file "/home/sam/OpenFOAM/OpenFOAM-v2006/tutorials/wigleyHull/0/alpha.alpha1"
From virtual Foam::autoPtr<Foam::ISstream> Foam::fileOperations::uncollatedFileOperation::rea dStream(Foam::regIOobject&, const Foam::fileName&, const Foam::word&, bool) const
in file global/fileOperations/uncollatedFileOperation/uncollatedFileOperation.C at line 546.
I tried copying alpha1 data into a new file with name alpha.alpha1 and then I get the following error
Exec : interFoam
Date : Sep 24 2020
Time : 21:55:12
PID : 3710
I/O : uncollated
nProcs : 1
Create time
--> FOAM Warning :
Using LTS
Reading field p_rgh
Reading field U
Selecting incompressible transport model Newtonian
Entry 'alpha.alpha1' not found in dictionary "/home/sam/OpenFOAM/OpenFOAM-v2006/tutorials/wigleyHull/system/fvSolution.solvers"
file: /home/sam/OpenFOAM/OpenFOAM-v2006/tutorials/wigleyHull/system/fvSolution.solvers at line 22 to 71.
From const Foam::dictionary& Foam::dictionary::subDict(const Foam::word&, Foam::keyType:ption) const
in file db/dictionary/dictionary.C at line 537.
FOAM exiting
hope someone can help
Regards
vava10
vava10 is offline   Reply With Quote
Old   September 24, 2020, 17:13
Krapf is on a distinguished road
I would guess that you need to define a solver for "alpha.alpha1" in fvSolution.
Krapf is offline   Reply With Quote
Old   September 25, 2020, 10:12
Deutschland
thank you.
It helped.
Building OpenFOAM1.7.0 from source ata OpenFOAM Installation 46 March 6, 2022 14:21
Second Derivative Zero - Boundary Condition fu-ki-pa OpenFOAM 11 March 27, 2021 05:28
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 10:00
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." sega OpenFOAM Community Contributions 12 February 17, 2010 10:30
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 18:38
