Pressure inlet boundary condition for icoFoam |
December 18, 2014, 20:57 |
Joseph Nichols
Rep Power: 11 |
Hi All,
I am trying to run a simple simulation of a leaky capillary using the icoFoam solver. I have run the same simulation using a solver I wrote for a class a few years ago and wanted to compare results. Unfortunately I am having trouble with the boundary conditions and am exasperated trying to solve the issue. The flow should be entirely pressure driven with fixed pressures at each boundary. My blockMeshDict looks like this Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 0.00001; vertices ( (0 0 0) (3 0 0) (4 0 0) (7 0 0) (0 1 0) (3 1 0) (4 1 0) (7 1 0) (0 1.1 0) (3 1.1 0) (4 1.1 0) (7 1.1 0) (0 4.1 0) (3 4.1 0) (4 4.1 0) (7 4.1 0) (0 0 0.1) (3 0 0.1) (4 0 0.1) (7 0 0.1) (0 1 0.1) (3 1 0.1) (4 1 0.1) (7 1 0.1) (0 1.1 0.1) //24 (3 1.1 0.1) //25 (4 1.1 0.1) //26 (7 1.1 0.1) //27 (0 4.1 0.1) //28 (3 4.1 0.1) //29 (4 4.1 0.1) //30 (7 4.1 0.1) //31 ); blocks ( hex (0 1 5 4 16 17 21 20) (30 10 1) simpleGrading (1 1 1) hex (1 2 6 5 17 18 22 21) (10 10 1) simpleGrading (1 1 1) hex (2 3 7 6 18 19 23 22) (30 10 1) simpleGrading (1 1 1) hex (5 6 10 9 21 22 26 25) (10 1 1) simpleGrading (1 1 1) hex (8 9 13 12 24 25 29 28) (30 30 1) simpleGrading (1 1 1) hex (9 10 14 13 25 26 30 29) (10 30 1) simpleGrading (1 1 1) hex (10 11 15 14 26 27 31 30) (30 30 1) simpleGrading (1 1 1) ) edges ( ); boundary ( inlet { type patch; faces ( (0 16 20 4) ); } outlet { type patch; faces ( (3 7 23 19) ) } tumorSide { type patch; faces ( (8 24 28 12) (12 28 29 13) (13 29 30 14) (14 30 31 15) (11 15 31 27) ) } capWall { type wall; faces ( (4 20 21 5) (6 22 23 7) (5 21 25 9) (6 10 26 22) (8 9 25 24) (10 11 27 26) (0 1 17 16) (1 2 18 17) (2 3 19 18) ); } frontAndBack { type empty; faces ( (0 4 5 1) (16 17 21 20) (1 5 6 2) (17 18 22 21) (2 6 7 3) (18 19 23 22) (5 9 10 6) (21 22 26 25) (8 12 13 9) (24 25 29 28) (9 13 14 10) (25 26 30 29) (10 14 15 11) (26 27 31 30) ); } ); mergePatchPairs ( ); // ************************************************************************* // Code:
FoamFile { version 2.0; format ascii; class volScalarField; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -2 0 0 0 0]; internalField uniform 1.2e5; boundaryField { inlet { type fixedValue; value uniform 1.5e8; } outlet { type fixedValue; value uniform 0; } tumorSide { type fixedValue; value uniform 1.2e5; } capWall { type zeroGradient; } frontAndBack { type empty; } } // ************************************************************************* // Code:
FoamFile { version 2.0; format ascii; class volVectorField; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { inlet { type zeroGradient; } outlet { type zeroGradient; } capWall { type fixedValue; value uniform (0 0 0); } tumorSide { type zeroGradient; } frontAndBack { type empty; } } // ************************************************************************* // pv_eruption.jpg The system is pretty simple so I am sure I am missing something simple, but I have spent all day trying to find it without success so any input would be appreciated. Thanks in advance, Joe edit: I just realized I didn't make it clear what my problem was. Rather than forward flow through my pipe, flow seems to be driven toward the walls where it quickly dies. I need to figure out how to develop normal flow through the system. Last edited by josephn; December 18, 2014 at 21:03. Reason: Clarification of problem |
December 23, 2014, 03:44 |
Found the problem
Joseph Nichols
Rep Power: 11 |
I was missing a semicolon in the blockMeshDict, so my outlet and walls were getting mixed up. Details, details...
blockmesh, boundary, icofoam |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 07:40 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 07:28 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 01:00 |
Setting outlet Pressure boundary condition using CAFFA code | Mukund Pondkule | Main CFD Forum | 0 | March 16, 2011 04:23 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 06:13 |
