Problem with multicomponentmixture initialization |
December 17, 2014, 10:43 |
Vincent RIVOLA
Rep Power: 18 |
Dear forumers,
I am currently trying to simulate the injection of different gases into air. So far, I had no problem simulating the injection of gas1 at inlet1. No problem either when I try to inject gas2 at inlet2 of my problem. I can also inject 50% of each gas at both inlets. So inlet1 is injecting 50% of gas1 and 50% of gas2. The same at inlet 2. It is actually working fine for any proportion of gas1/gas2 EXCEPT 100% / 0% for one of the two gases. So I can't inject 100% gas1 at inlet1 and at the same time 100% of gas2 at inlet2. For all these cases, I don't inject any air at the inlets (so fixedValue BC at 0.0 for specie air). When I say that it does not work, it is that I get an fpe when the code is building the thermoPhysicalModel. Even more strange, the behaviour is changing depending on the order of declaration of species in the thermophysicalDict file! Here are some informations on the settings: - thermophysicalProperties: Code:
thermoType { type hePsiThermo; mixture multiComponentMixture; transport const; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleInternalEnergy; } species ( air gas1 gas2 ); inertSpecie air; air { specie { nMoles 1; molWeight 28.97; } thermodynamics { Cp 1005; Hf 0; } transport { mu 1.78e-05; Pr 0.7; } } gas1 { specie { nMoles 1; molWeight 29.56; } thermodynamics { Cp 2445; Hf 0; } transport { mu 9e-05; Pr 0.7; } } gas2 { specie { nMoles 1; molWeight 16.55; } thermodynamics { Cp 2894.53; Hf 0; } transport { mu 9e-05; Pr 0.7; } } Code:
dimensions [0 0 0 0 0 0 0]; internalField uniform 0.0; boundaryField { "inlet1" { type fixedValue; value uniform 1.0; } "inlet2" { type fixedValue; value uniform 0.0; } .... } Code:
dimensions [0 0 0 0 0 0 0]; internalField uniform 0.0; boundaryField { "inlet1" { type fixedValue; value uniform 0.0; } "inlet2" { type fixedValue; value uniform 1.0; } .... } Code:
dimensions [0 0 0 0 0 0 0]; internalField uniform 1.0; boundaryField { "inlet1" { type fixedValue; value uniform 0.0; } "inlet2" { type fixedValue; value uniform 0.0; } .... } Code:
Reading thermophysical properties Selecting thermodynamics package { type hePsiThermo; mixture multiComponentMixture; transport const; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleInternalEnergy; } #0 Foam::error::printStack(Foam::Ostream&) in "/CFDBB/vincent/OpenFOAM//OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #1 Foam::sigFpe::sigHandler(int) in "/CFDBB/vincent/OpenFOAM//OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #2 in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::multiComponentMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> > >::patchFaceMixture(int, int) const in "/CFDBB/vincent/OpenFOAM//OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libreactionThermophysicalModels.so" #4 Foam::heThermo<Foam::psiReactionThermo, Foam::SpecieMixture<Foam::multiComponentMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> > > > >::he(Foam::Field<double> const&, Foam::Field<double> const&, int) const in "/CFDBB/vincent/OpenFOAM//OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libreactionThermophysicalModels.so" #5 Foam::heThermo<Foam::psiReactionThermo, Foam::SpecieMixture<Foam::multiComponentMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> > > > >::init() in "/CFDBB/vincent/OpenFOAM//OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libreactionThermophysicalModels.so" #6 Foam::heThermo<Foam::psiReactionThermo, Foam::SpecieMixture<Foam::multiComponentMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> > > > >::heThermo(Foam::fvMesh const&, Foam::word const&) in "/CFDBB/vincent/OpenFOAM//OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libreactionThermophysicalModels.so" #7 Foam::psiReactionThermo::addfvMeshConstructorToTable<Foam::hePsiThermo<Foam::psiReactionThermo, Foam::SpecieMixture<Foam::multiComponentMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> > > > > >::New(Foam::fvMesh const&, Foam::word const&) in "/CFDBB/vincent/OpenFOAM//OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libreactionThermophysicalModels.so" #8 Foam::autoPtr<Foam::psiReactionThermo> Foam::basicThermo::New<Foam::psiReactionThermo>(Foam::fvMesh const&, Foam::word const&) in "/CFDBB/vincent/OpenFOAM//OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libreactionThermophysicalModels.so" #9 Foam::psiReactionThermo::New(Foam::fvMesh const&, Foam::word const&) in "/CFDBB/vincent/OpenFOAM//OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libreactionThermophysicalModels.so" Does someone has an idea on what's going on? |
January 6, 2015, 09:45 |
Yu-sen Niu
Rep Power: 12 |
Hi, I have meet the similar problem. Can U email me your case, so that I can learn how to deal with boundary condition and initial conditon. In addition, my case includes 4 cellZones, and I want to patch different values for different cellZone as initial condition. Can U tell me how to do this?
Thank U very much! |
initialization problem in fluent | morteza08 | Main CFD Forum | 0 | January 17, 2011 13:04 |
Initialization problem when using Axisymmetry BC | Eduardo | FLUENT | 0 | August 4, 2008 10:23 |
coal combustion initialization problem | Chetan Prahsant | CFX | 1 | May 1, 2007 06:41 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 20:13 |
Is this problem well posed? | Thomas P. Abraham | Main CFD Forum | 5 | September 8, 1999 15:52 |
