Adding passive scalar transport for incompressible flows
Old   December 16, 2014, 01:09
Default Adding passive scalar transport for incompressible flows
Thangam Natarajan
Thangam is on a distinguished road
Hi
I am simulating an unsteady turbulent jet where air is released into a quiescent medium of air. I am trying to add passive scalar to my inlet (like a dye or tracer and no reactions) for the following reasons:
1) To monitor the concentration change due to diffusion and mixing.
2) To have a better visualizations since I assume they would take different colors in post processing since they are two different species though both are air.(I have attached a picture (westerweel et al. 2009)
A couple of ways I thought to do this:
1) rewrite scalarTransportFoam for concentration instead of temperature.
2) use reactingFoam with exactly the same properties for the species with no reaction and no combustion. However I failed to understand the difference between reactingFoam and RhoReactingFoam and I believe both are for compressible flows.Hence, rewrite a solver for incompressible flows?
3) Use interFoam and use similar properties for both the fluids
However I am not sure if any of the above would work though!
Any thoughts would be appreciated!
Thanks!
Thangam is offline   Reply With Quote
Old   December 16, 2014, 02:48
Yogesh Bapat
ybapat is on a distinguished road
I think you can use scalarTransportFoam directly as it is transient solver for passive scalar.
-Yogesh
ybapat is offline   Reply With Quote
Old   December 16, 2014, 03:17
Thangam Natarajan
Thanks Yogesh. I guess the scalarTransportFoam solves for the temperature as the transported scalar which I dont require in my case. I need something like a tracer that varies in concentration as diffusion takes place.
Old   December 16, 2014, 05:01
Olivier
olivierG is on a distinguished road
Take a look at the function Object "scalarTransport". Just add it in you controlDict + tracer name in 0 dict, and your done. Work will most of OF solver.
You can find some example in this forum.
regards,
olivier
olivierG is offline   Reply With Quote
Old   April 2, 2015, 19:04
howgee
cfd_inquirer is on a distinguished road
hello there OliverG. I was trying to do what you said but it seemed like OpenFOAM ver 2.2.2 (what am using) doesn't recognize the
type scalarTransport
as a function object. :-(
Do you know where I could find such example? Thanks in advance.
cfd_inquirer is offline   Reply With Quote
concentrations, reacting foam, scalar transport, turbulence analysis
how to make a scalar transport equation to be conserved? immortality OpenFOAM Programming & Development 3 May 5, 2013 09:11
icoFoam with multiRegion and passive scalar transport RugbyGandalf OpenFOAM Programming & Development 1 January 2, 2013 03:41
Generic Scalar Transport Equations venkyr56 Main CFD Forum 4 February 6, 2011 06:20
Is it possible to use divergence in the source term of an scalar transport equation? jannnesss CFX 0 January 8, 2010 20:53
transport equation for SGS scalar variance chinthakindi Main CFD Forum 0 April 27, 2004 10:26
