Reading Boundary Condition from a File
Old   December 10, 2014, 13:51
Default Reading Boundary Condition from a File
Shabir Mohamed
Shabirmean is on a distinguished road
I have a case where I want the height and the velocities at the Inlet boundary to be read from a data file "EVERY TIME STEP".
The deltaT is "0.001". The simulation runs for only one(1) second.
Hence my datafile contains 1000 entries for height Data which needs to be read every timestep as the boundary condition at the Inlet.
I am using OF3.1extended. Can someone help me??
Is there a way to properly do this in OpenFOAM 3.1 and if so are there any tutorials or examples to see......
I came across something called timeVaryingFixedValue which interpolates the values I give. However I want something that can read everytime step!!!!
Please help.. It is an urgent need for my undergraduate research....
Shabirmean is offline   Reply With Quote
Old   December 13, 2014, 12:48
Florian Ries
itchy is on a distinguished road
you can use timeVaryingFixedValue and choose the time step in controlDict equal to your deltaT of 0.001.
kind regards
Florian
itchy is offline   Reply With Quote
Old   December 13, 2014, 13:46
Default any examples
Shabir Mohamed
Thank You
Can you please be descriptive about how the case should be set??
Are there any examples to refer?
Like other than the BC type what other fields are to be set and how the time directories need to be defined!!!
boundary condition, inlet boundary condition
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc ofslcm OpenFOAM Community Contributions 25 March 6, 2017 11:03
Problem compiling a custom Lagrangian library brbbhatti OpenFOAM Programming & Development 2 July 7, 2014 12:32
Trouble compiling utilities using source-built OpenFOAM Artur OpenFOAM Programming & Development 14 October 29, 2013 11:59
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 12:44
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
