how to set correctly the porosity properties to use porousInterFoam?
Old   December 3, 2014, 04:57
Default how to set correctly the porosity properties to use porousInterFoam?
otadol
cramsdead is on a distinguished road
Hello Foamers !
I would like to know how to set the porosity properties correctly.
Please someome can advise me? Explain me how to set correctly the porosity properties?
I would like a permeability of 5e-11 mē
and trying some different porosity on : like 0,3 0,5 0,8
Is it right?
into the line :
d d [0 -2 0 0 0 0 0] (X X X);
(X X X) is the porosity coefficient divided by the permeability coeff? (here the same in all directions)
Is it right?
| \\ / O peration | Version: 2.2.1 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "constant";
object porosityProperties;
porosity1
type DarcyForchheimer;
active yes;
cellZone porouszone;
porosity 0.5;
permeability 5e-11;
DarcyForchheimerCoeffs
mu mu;
d d [0 -2 0 0 0 0 0] (0.1e11 0.1e11 0.1e11); //0.5/5e-11=0.1e11
f f [0 -1 0 0 0 0 0] (0 0 0);
//coordinateSystem
// e1 (0.70710678 0.70710678 0);
// e2 (0 0 1);
I know there is an other post about this but was only fonded about suppositions. I want to be sure!
Thanks a lot for considering my post.
cramsdead is offline   Reply With Quote
Old   December 4, 2014, 08:13
otadol
please anyone?
Old   December 4, 2014, 12:06
Hao Chen
hchen is on a distinguished road
D is the porous resistance coefficient.
Darcy-Freidheim formula basically says S = d*u+F*mag(U)*U.
Best regards
Hao
hchen is offline   Reply With Quote
Old   December 8, 2014, 05:38
otadol
ok I got it :
The permeability k is generally expressed in Darcy (D). Hao, I think you mean the porous resistance coeff right?
One Darcy is the permeability of a continuous, isotropic body through which a fluid of similar viscosity to that of water at 20 ° C flowing at a speed of 1 cm · s-1 when subjected to a pressure of 1 atm, which corresponds to the dimension of a surface. 1 D = 0.97 Ũ 10-12 mē
The term hydraulic conductivity (K or permeability coefficient) is the ratio between the permeability and the viscosity of the fluid (the fluid is usually water). More a environement is permeable, more the fluid will flow quickly.
Hydraulic conductivity is expressed in m⋅s-1
So here into the d d [0 -2 0 0 0 0 0] (X X X);
X is the "k" permeability coefficient. This is just so weird OpenFoam ask d in m^-2 and not in mē...
So my last question is : for a permeability of 5e-11 I have to set X=5e11 OR X=0,2e11?
I donīt think we need to set the porosity coefficient here. This is 2 things really different.
thank you for your reply.
Old   December 8, 2014, 17:56
Hao Chen
I am sorry that I am not an expert in hydraulics, but somehow you are right that permeability is expressed as D and F. However when you consider Darcy law, you need to put it into NS equation and the additional term S should have the same dimension with original NS equation. That is why D and F has that dimension. I remember that I read some paper describing relation between D and k, but I can not remember. You can check some papers on porous media.
Porosity does not have anything to do with D and F. It does not occur in openfoam native porous media library.
Best regards
Hao
Old   December 10, 2014, 04:43
otadol
Hi Hao,
Thanks a lot for your reply, I was asking for that to be sure that "normally" porosity does have anything to do with D and F but it seems there is a little trick about it as explained in the following post :
http://www.cfd-online.com/Forums/ope...interfoam.html
So I think Iīm gonna try it into my simulations.
Well, my last question is : for a permeability of 5e-11 I have to set X=5e11 OR X=0,2e11?
Because I donīt want to do an easy mistake like this.
Thank you for your reply,
Cheers
porosity
[ICEM] ICEM Scripting Issues tylerplowright ANSYS Meshing & Geometry 33 September 27, 2021 17:35
[General] 2 datas on one plot Akuji ParaView 46 December 1, 2013 15:06
udf inlet velocity is not set correctly, why ? GaoGe FLUENT 0 June 17, 2008 09:33
Problems with installation jonititan OpenFOAM Installation 4 November 6, 2005 05:16
how correctly set up BC for compressible flows.... yann Phoenics 5 October 13, 2003 04:35
