Rotational Rheometry
Old   December 1, 2014, 10:54
Default Rotational Rheometry
Nithish
nithishgupta is on a distinguished road
Hello All,
I am trying to solve a problem, my geometry has two parallel plates. With bottom plate as fixed and top plate is moving plate. With applied force and angular velocity it pushes the top plate downwards until it reaches a gap width of 1mm.
What i dont understand is how can i define fluid in between the two plates, here there is no inlet or outlet fluid has to be defined in between the two plates.
My questions are:
1.How can i define angular velocity for the top plate.
2.How can i define no slip boundary conditions between the two plates.
3. Which solver I can use > ?
I am new to openFoam and trying to learn, any help is appreciated. Thank you for your help in advance.
Attached is my geometry.
nithishgupta is offline   Reply With Quote
Old   December 2, 2014, 03:53
maHein is on a distinguished road
1) You can use "rotatingWallVelocity" as boundary condition for U at the upper wall to apply a angular velocity at the wall.
2) Using a fixedValue boundary condition for the lower wall with a value of (0 0 0) and point 1) will result in no-slip boundaries.
3) If you are planing on using a dynamic mesh for handling the movement of the plates, you could use pimpleDyMFoam as a solver.
Regards,
Martin
maHein is offline   Reply With Quote
mesh 3d, simplefoam
How Do I change rad/s - time rotational speed spaces melek FLOW-3D 0 November 7, 2013 08:22
[Commercial meshers] Rotational cyclic BC in ICEM generated mesh esgee OpenFOAM Meshing & Mesh Conversion 0 May 8, 2013 09:42
[ICEM] Rotational periodicy setup Procyon ANSYS Meshing & Geometry 0 April 30, 2011 08:55
max rotational velocity of VAWT by CFD CFD-beginner Main CFD Forum 0 April 5, 2010 00:04
