Modelling Torricelli cylindre with buoyantSimpleFoam - problem with p_rgh |
November 22, 2014, 18:17 |
Coheur
Dear Foamers,
I would like to modelize a case like in the Torricelli's cylinder (http://en.wikipedia.org/wiki/Torricelli%27s_law) with one inlet at the top and three outlets on the right side. I'm using buoyantSimpleFoam, removing turbulence and setting the temperature constant, so that I only have the effect of the gravity influencing my flow. I'm using atmospheric pressure for the BC of my three outlets for p_rgh and a small velocity is imposed at the inlet. p field is calculated from p_rgh. Pressure fields p_rgh and p are correctly computed, but since openFoam compute U using p_rgh = p - rho*g*h, I don't see the effect of the gravity on the flow (in fact, it is the same as using icoFoam, velocities at the three outlets are the same). I would like to use p instead of p_rgh to have my flow with different velocities at the outlet. The questions are: How can I make openFoam using my static pressure p? Should I use an other solver for my problem? Here are the results obtained for velocity field U, p and p_rgh Thanks in advance Joffrey Last edited by jocoheur; November 23, 2014 at 15:32. Reason: add pictures |
buoyantsimplefoam, gravity driven, openfoam, p_rgh, torricelli |
Fan Modelling Problem in CFX | Jenny | CFX | 8 | September 11, 2007 14:59 |
SST-DES modelling problem | Yang | CFX | 2 | May 18, 2007 07:22 |
Problem with VOF open channel modelling | Biswanath Mahato | FLUENT | 1 | September 14, 2006 05:20 |
problem about modelling fluidized bed! | xfish | FLUENT | 3 | November 6, 2003 09:42 |
modelling of conjugate heat transfer problem | ajay chandra | FLUENT | 1 | October 28, 2003 07:51 |
