November 18, 2014, 00:01 |
powerLaw model
Yongxiao Wang
Rep Power: 12 |
Hello there,
I am simulating a non-Newtonian fluid using nonNewtonianIcoFoam solver. I modify the tansportProperties as follows: Code:
transportModel powerLaw; nu nu [ 0 2 -1 0 0 0 0 ] 1; powerLawCoeffs { k k [ 0 2 -1 0 0 0 0 ] 2800; n n [ 0 0 0 0 0 0 0 ] 0.64; nuMin nuMin [ 0 2 -1 0 0 0 0 ] 0.1; nuMax nuMax [ 0 2 -1 0 0 0 0 ] 10000000; } Courant Number mean: 111.265 max: 581.185 #0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam230/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam230/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #2 Uninterpreted: #3 Foam::symGaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int) in "/opt/openfoam230/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #4 Foam::symGaussSeidelSmoother::smooth(Foam::Field<d ouble>&, Foam::Field<double> const&, unsigned char, int) const in "/opt/openfoam230/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #5 Foam::smoothSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam230/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #6 in "/opt/openfoam230/platforms/linuxGccDPOpt/bin/nonNewtonianIcoFoam" #7 in "/opt/openfoam230/platforms/linuxGccDPOpt/bin/nonNewtonianIcoFoam" #8 in "/opt/openfoam230/platforms/linuxGccDPOpt/bin/nonNewtonianIcoFoam" #9 in "/opt/openfoam230/platforms/linuxGccDPOpt/bin/nonNewtonianIcoFoam" #10 __libc_start_main in "/lib/i386-linux-gnu/libc.so.6" #11 in "/opt/openfoam230/platforms/linuxGccDPOpt/bin/nonNewtonianIcoFoam" if I use the powerLaw model in the my simulation, how should I do? Thanks! Yongxiao |
November 18, 2014, 03:35 |
Yongxiao Wang
Rep Power: 12 |
I have found the reason of the error.
When I change the "nuMax" to a small number (e.g. 100 or even 10000 ), it can be running without any error. But why? Can someone please explain it? |
eddy dissipation model: combustion doesn't occur | roukaia | FLUENT | 2 | November 18, 2020 11:23 |
problem with solving lagrange reaction cloud | Polli | OpenFOAM Running, Solving & CFD | 0 | April 30, 2014 08:53 |
manualInjection model in sprayFoam | Mentalo | OpenFOAM Running, Solving & CFD | 1 | April 2, 2014 10:29 |
eddy dissipation model: combustion doesn't occur | roukaia | FLUENT | 0 | December 24, 2011 10:10 |
Problems bout CFD model of biomass gasification, Downdraft gasifier | wanglong | FLUENT | 2 | November 26, 2009 00:27 |
