November 16, 2014, 16:37 |
Final Residue - Convergence
vitor spadeto
Rep Power: 12 |
Friends, my simulation it is running with this final residual:
see the printscreen: http://postimg.org/image/m3cdjmkcd/ Well, the mesh is a little large ... looks like it will not converge. The solver is simpleFoam. It took 4 hours to get this time of image attachment. this value is already waste from many previous iterations. The question is: What does this mean value of Final Residual ? In this final Residual values, Have good results? I'm newbie, could you help me? Wanted to know if this simulation can be aborted ja ... For example, if I cancel the simulation final residue in this range (eg late residue Uy = 0.0007), means that the speeds at each point of the flow can be very large errors? can give me a better interpretation? I think the source of this lack of convergence is caused by SALOME. Could not generate a better mesh for him. It's the best software I've seen so far (opensource) to generate mesh for openfoam. Best Regards |
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 03:20 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
pimpleFoam: turbulence->correct(); is not executed when using residualControl | hfs | OpenFOAM Running, Solving & CFD | 3 | October 29, 2013 09:35 |
calculation stops after few time steps | sivakumar | OpenFOAM Running, Solving & CFD | 7 | March 17, 2013 07:37 |
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 06:24 |
