Run time monitoring of velocity or flux
Old   November 14, 2014, 06:52
Default Run time monitoring of velocity or flux
Filip Gjetvaj
File is on a distinguished road
I'm running a steady state simulation (simpleFoam solver) and would like to know if there is some option to monitor flux at outlet at run time.
For now at the end of simulation I run patchAverage or patchIntegrate over phi field and compare flux results at different step. Limit of this approach is that there are values in just few time step (otherwise too much data to process) and also have to wait for the simulation to end.
Is it possible to run it during the simulation and keep just a value for each step (instead whole flow field). I found sampleDict option but not sure how it works could you please tell me if this could be what I'm looking for?
It is important to say that simulation runs in parallel
File is offline   Reply With Quote
Old   November 14, 2014, 09:22
Joachim Herb
jherb is on a distinguished road
You need the simpleFunctionObject library from swak4foam. Then you can add something like
functions
   postFields
       type patchAverage;
       functionObjectLibs
         "libsimpleFunctionObjects.so"
       verbose true;
       patches
         INLET
         OUTLET
         inlet
         outlet
       fields
         T
         p
         U
       outputControl timeStep;
       outputInterval 1;
to your system/controlDict
jherb is offline   Reply With Quote
Old   November 14, 2014, 10:54
Filip Gjetvaj
Thank you very much Joachim
this was exactly what I was looking for
it works like a charm
Old   May 19, 2016, 06:58
thomas
thomas. is on a distinguished road
do you have any experiences with foamMonitor? Why do you prefer this alternative instead of the foamMonitor one?
Thanks in advance!
thomas. is offline   Reply With Quote
flux, run time
simpleFoam error - "Floating point exception" mbcx4jc2 OpenFOAM Running, Solving & CFD 12 August 4, 2015 03:20
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
dynamic Mesh is faster than MRF???? sharonyue OpenFOAM Running, Solving & CFD 14 August 26, 2013 08:47
Problem with time average tangential velocity in swirl flow. lakhi FLUENT 5 July 18, 2012 17:28
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
