Pressure units
Old   November 13, 2014, 04:06
Default Pressure units
Na
Eranho is on a distinguished road
Hi!
I'm modeling gas flow trough statical mixer. I'm using Pascals in my boundary conditions (dimensions [1 -1 -2 0 0 0 0] . I'm using swak4foam to calculate pressure drop between inlet and outlet:
    pressureDrop
        type patchExpression;
        variables (
            "pOut{patch'outlet}=sum(p*area())/sum(area());"
            "inArea=sum(area());"
        accumulations (
           sum
        patches (
            inlet
        expression "area()*(p-pOut)/inArea";
        verbose true;
The problem is that the calculated pressure drop is much less than expected. Which units is applied in swak4foam output?
OF 2.1.1
solver: rhoSimplecFoam
Thanks
-Eranho
Eranho is offline   Reply With Quote
Pressure Inlet VS velocity Inlet difference Mohsin FLUENT 9 January 4, 2021 11:34
Pressure units in incompressible solvers Per OpenFOAM Running, Solving & CFD 4 July 19, 2019 04:43
Pressure Outlet Guage pressure Mohsin FLUENT 36 April 29, 2016 18:16
Pulsatile pressure inlet with pressure outlet a.lynchy FLUENT 3 March 23, 2012 14:45
UDF to define or adjust pressure??? engahmed FLUENT 0 July 6, 2010 18:19
