November 12, 2014, 13:44 |
LES Boundary Conditions for Pipe Flow
Marco A. Turcios
Rep Power: 28 |
Hello everyone,
I am currently trying to model some spray evaporation and chemistry and want to start using LES to resolve the spray velocity distribution better. I was previously using RANS w/k-epsilon and obtaining decent flow with the following BCs: U: inlet = fixedValue (average U) outlet = zeroGradient p: inlet = inletOutlet outlet = outletInlet k: inlet = calculated outlet = zeroGradient When running the same case in LES, I get very peculiar velocity fluctuations (pictures attached). Not a ton of experience with LES, so I figure there is a better way to set the BC. Inlet is on the left side, outlet on the right. Cylindrical pipe with walls BC specified for each. Length is 8m, diameter is 0.3m. Using an O-grid, total cells are about 320K Thanks! Last edited by mturcios777; November 13, 2014 at 13:20. Reason: Added domain info |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 07:40 |
Appropriate Boundary conditions for jet flow in open domain | shrutidhara.123 | FLUENT | 0 | August 5, 2014 11:27 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 18:11 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 05:05 |
Boundary Conditions for Incompressible Flow | Bob | FLUENT | 0 | April 7, 2006 22:28 |
