Trying to validate fvDOM and view factors methods |
June 12, 2015, 05:03 |
#21 |
RobinZ
Rep Power: 12 |
Hi Alex,
did you ever tried to change the number of rays for your fvDOM calculation? In your posted radiationProperties i can see your nPhi is 3 and your nTheta is 5, that's ok but that will not give you a uniformly field of rays. nPhi are the number of rays over 90° azimuthal nTheta over 180° polar So if you want to solve the field equidistant it is more useful to take 2*nPhi for the nTheta value. When you rise the number of rays the failure you make by simplify the radiation field with a definite number of rays will decrease. The other question is: why do you have defined G? The G BC is only used in the P1 model. IDefault is for fvDOM an Qr for viewFactor model. The generated fields differ to that. best regards Robin |
June 12, 2015, 09:11 |
#22 | |
Alex
Rep Power: 22 |
Thanks for your insight and your advices. Some days ago I found that chosing an odd number of nTheta provokes an unexpected behavior in the radiation calculation. See a deep analysis here and feel free to respond if you have some knowledge on the matter. With regard to the definition of G in the fvDOM, I didn't know it was not necessary to define it! I have always done it because I started my fvDOM calculations with the "hotRadiationRoomFvDOM" tutorial under "tutorials/heatTransfer/buoyantSimpleFoam" and, if you take a look into that case, you will see that G is also specified... Besides that, if you execute the following command in the terminal: Code:
find $FOAM_TUTORIALS -iname "rad*prop*" | xargs grep -il fvdom Best regards, Alex
Web site where I present my Master's Thesis: foamingtime.wordpress.com The case I talk about in this site was solved with chtMultiRegionSimpleFoam solver and involves radiation. Some basic tutorials are also resolved step by step in the web. If you are interested in these matters, you are invited to come in! |
June 12, 2015, 10:07 |
#23 |
RobinZ
Rep Power: 12 |
First of all it's an interesting behaviour of the fvDOM model you have in your Case.
I never tried to use a odd number for nTheta. I always tried to have the same angles of polar and azimuthal between the rays, so nTheta=2*nPhi like i've mentioned before. Then to the G BC topic. I know it is often specified in the tutorials, but when you look in the code of viewFactor.C or fvDOM.C you will see that G don't have to be specified. You already seen that by running your Case without the G BC. To your Case how fine is your grid? I've seen a paper in which is mentioned, that the grid spacing have an enourmous influence on the quality of the radiation results. I've attached a .png from the paper. So i think you can make your results better by increasing the number of rays and decreasing your grid spacing. Finally i have an own question on the viewFactor model. In the radiationProperties you can specify the viewFactorCoeffs. I don't find the influence(if there is one) of constantEmissivity. I run some testcases and i see no difference if i set it false or true. I already checked the source code of viewFactor.C and .H but for now in which i can see there is no difference for calculating the radiation in the end. Best regards Robin |
June 12, 2015, 10:35 |
#24 |
Alex
Rep Power: 22 |
Thanks for the information about the grid spacing. Is that paper written in german? If the answer is no, can you please attach it here?
Regarding the question related to the view factors I can't help you much for now...
June 12, 2015, 10:45 |
#25 |
RobinZ
Rep Power: 12 |
The answer is yes it is written in german.
That's why i did not posted it in my last reply. Sorry. I will open a new thread for my question on the viewFactor model. Hopefully someone else have more experience with this model and is able to answer my question. Good luck for your case, perhaps my annotations will help you. best regards Robin |
May 23, 2018, 09:46 |
#26 |
Dear olivier,
If you chould share your validation case of S2S and DO on this website? Best regards, Chengan |
July 24, 2018, 15:45 |
#27 | |
Sergei
Rep Power: 22 |
June 8, 2021, 08:26 |
#28 |
JuanMi
Rep Power: 9 |
I had a similar problem and found the solution recently. I am sharing it in this thread so that people can check it out. Both the viewFactor model and the fvDOM model create fields named G and qr. You have to be very aware of this, as the fvDOM, in its initial conditions, does not require qr, but viewFactors does. In case of including qr in the initial conditions (folder 0) for the fvDOM case, the calculations will be WRONG (likely). That happened to me. I copied the case with viewFactors to the fvDOM case, adding only the boundary conditions corresponding to IDefault. By not removing qr. In this way, boundary conditions for qr were being imposed that prevented fvDOM from reaching the good result. Also watch out for G. |
August 25, 2021, 02:48 |
#29 |
Bushra Rasheed
Rep Power: 5 |
Hi! I am trying to use fvDOM to simulate UV radiations. Can anyone guide if we can define wavelength band in fvDOM? I know there is nLambda in code of fvDOM but I don't know how do we define it in radiationProperties in constant folder.
Thanks! |
August 25, 2021, 03:46 |
#30 |
JuanMi
Rep Power: 9 |
Take a look to :
https://github.com/OpenFOAM/OpenFOAM-9/blob/master/src/radiationModels/absorptionEmissionModels/ If it is not suitable for you, try to implement a new absorptionEmissionModel to be in the range of UV. Another option is modifying fvDOM. Create a new emissor different from BlackBody emission https://github.com/OpenFOAM/OpenFOAM...ckBodyEmission |
August 25, 2021, 03:57 |
#31 | |
JuanMi
Rep Power: 9 |
https://github.com/OpenFOAM/OpenFOAM...ckBodyEmission Another option would be modifying the emissivity. Take a look to: https://github.com/OpenFOAM/OpenFOAM...EmissionModels |
August 25, 2021, 05:16 |
#32 | |
Bushra Rasheed
Rep Power: 5 |
There will not be any obstacle so I can turn off absorption. I just need a boundary emitting UV rays. Does that still need modifying blackBodyEmissions? |
August 25, 2021, 06:07 |
#33 | |
JuanMi
Rep Power: 9 |
I am practically certain that the correct way is creating a new BC for your emitting surface, similar to https://github.com/OpenFOAM/OpenFOAM...usiveRadiation Obviously, your surface could be diffusive but not grey and emissivity depends on temperature and wavelength. For that reason I proposed you the "hack" of changing the blackBodyEmission instead of creating a new BC. It's not at all the ideal way, but my mind is not capable of anything else at the moment. I think it could work. |
August 25, 2021, 08:58 |
#34 | |
Bushra Rasheed
Rep Power: 5 |
Also, fvDOM source code mentions nLambda but it is not asked from user or calculated anywhere else in the code. Do you know how does openfoam calculate nLmabda in fvDOM? |
chtmultiregion, fvdom, radiation, thermal baffles, viewfactor |
