November 12, 2014, 08:13 |
buoyantBoussinesqSimpleFoam
Rep Power: 12 |
Good Morning!
I'm pretty new in OpenFOAM so I hope you could help me with my problems. I have made without any problems the pitzDaily tutorial, I could see the evolution of its pressure and velocity. Now I had the idea of introducing temperature in this same model. For this I used "buoyantBoussinesqSimpleFoam", which I guess it is correct, but I'm not sure. The procedure I have followed is very simple: I was adding and changing the files and commands which I was required by the different errors in my terminal. I achieved to do almost everything, but I can't follow now. The problem is that, when I write the solver in my terminal this error message appears: PHP Code:
My main question is if I'm following the right procedure to convert a p&U model into a p&U&T model, because I need it for my particular project. Also if the solver I am using is the correct one. I attach my 0 and systems files (U is the initial file, because the potential one weighs too much). Thank you really much Last edited by Wien3; November 19, 2014 at 09:47. |
November 12, 2014, 15:15 |
Kumar
Rep Power: 13 |
Change your outlet boundary for p_rgh as follows and see what happens: type fixedValue; value uniform 0; |
November 13, 2014, 10:12 |
Rep Power: 12 |
Thank you very much! It was useful!
I will make another post relating to my own model, if you could help me there it would be great |
