question regarding LES of pipe flow - pimpleFoam
Like Tree9Likes
Old   November 18, 2014, 04:17
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
But does it work now, with a correct mesh?
Btw: You need to change p solver to GAMG as I wrote above...
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
Old   November 19, 2014, 01:43
Daniel
Dan1788 is on a distinguished road
It still does not work, even with the correct mesh. Thanks for your suggestions nonetheless
Yes I do wall resolved LES. I am not sure about the boundary condition for k at the wall. Conceptually you are right that for a WR LES it needs to be 0. As for the nuSgs I suppose OF requires a nuSGS file in the 0 folder and I dont think the boundary conditions are used.
I am going to try perturbing the flow with turbulence to see how that works out. Have you ever tried that option?
btw, could you upload your pipe case for reference?
Dan1788 is offline   Reply With Quote
Old   November 19, 2014, 04:18
Philipp
Yes,
here it is.
LES_pipe.tar.gz
Can you upload your mesh somewhere?
One thing: In your first pictures you show a turbulent profile (from one-eq. model), in your last pictures this looks like a laminar profile. Maybe the first was right, but you expect too much turbulence...
Old   November 19, 2014, 04:25
Philipp
Yes, I think thats right.
Old   November 20, 2014, 18:49
Daniel
Sure, since the mesh is big if you can give me your email or dropbox ID I can send it to you. As for the pictures I think both are laminar flow just that earlier I used paraview and then Tecplot to show the contours. I think there should be an eddy like structure, similar to how your contours look (but corrrect me if I am wrong). Thanks for sharing your case though
Old   November 27, 2014, 04:31
Philipp
Daniel, I put the case on our server and let it run. I couldn't find any obvious mistake. You still need to wait a bit.
Old   November 27, 2014, 16:10
Daniel
Appreciate your help Philipp :-)
let me know if you happen to find anything.
Old   November 28, 2014, 07:12
Philipp
Daniel, after struggling that much without any outcome I try something different: I changed the boundary conditions from cyclic to mapped. I also made a thread about cyclic pipes for a different bur similar problem:
http://www.cfd-online.com/Forums/ope...-unstable.html
So, maybe that will work. I can tell you after the weekend
Old   December 2, 2014, 03:35
Philipp
Ok, It doesn't work either. I give up... maybe someone else can help.
Old   December 3, 2014, 00:26
Daniel
Hey,
I think because my reynolds number is less just by solving the equations without initializing turbulence wont help. But thanks for your help anyways. I am now trying to solve the problem by giving turbulence using boxTurb. Let me see how that goes.
Will let you know if I manage to get some good results
Old   January 3, 2015, 14:26
Likun
Likun is on a distinguished road
Send a message via Skype™ to Likun
Hi Daniel,
Have you solved your problem? I am trying to do LES for a pipe flow, but similar to the results that you shown in your first post of this thread, I don's see any turbulent structure after a very long time. Can you give some hints on the reason and solution for this problem?
Best,
Likun
Likun is offline   Reply With Quote
Old   January 5, 2015, 10:15
Daniel
Originally Posted by Likun View Post
Hi Daniel,
Best,
Likun
Hi Likun,
I found the solution of this problem by using boxTurb utility in a square duct of the same length as the pipe to generate turbulence. Then mapping the turbulence from the duct to the pipe using the mapFields utility. This will be the initial condition which if you let run would give you turbulent structures in the flowfield.
Let me know if you need any other clarification.
Old   January 6, 2015, 04:30
Likun
Hi Daniel,
Thank you for your reply. I did what you suggested, and now my pipe is turbulent. However, I still have one doubt about the level of perturbation using boxTurb. I first generated a relatively small fluctuation with boxTurb, but then the turbulence was killed after some iterations. However, with a larger perturbation at the beginning (same order of the main velocity component), the turbulence survived. My question is that, does the extent of perturbation at the beginning influences the final results? Do you (or anybody) have any idea on what should be a proper level of perturbation?
Thanks in advance!
Best,
Likun
Old   January 11, 2015, 02:12
Daniel
Hi Daniel,
Thanks in advance!
Best,
Likun
Hi Likun,
I am not entirely sure how the extent of perturbation affects the results because I havent really done a parametric study. Usually I have always taken the perturbation to be approximately 10% of the bulk velocity which is known. Hope that helps!
Old   January 12, 2015, 15:51
Likun
Dear Daniel,
Thank you for your reply. I think the initial perturbation should not influence the final results as long as the perturbation is enough to trigger turbulence. I simulated to pipe flow over a long time. The resolved kinetic energy seems does not change much over time. So, I think this should be converged.
Best,
Likun
Old   December 14, 2016, 05:34
Default streamwise or spanwise vortices
  #36
Nitin
Nitin Minocha is on a distinguished road
Dear Daniel
I am doing DNS channel flow in openfoam. I am unable to found streamwise or spanwise vortices even after 8000s. I would like to know how you solve your problem.
Nitin Minocha is offline   Reply With Quote
Old   December 24, 2017, 10:26
Default Hi
  #37
gu1
Guilherme
gu1 is on a distinguished road
Originally Posted by RodriguezFatz View Post
This is a picture of a pipe flow just as you do, but with higher Re and wall modeled LES. It was initialized without any turbulence.
Attachment 34955
This is a picture of the kinetic energy (perpendicular to the main flow) to track the convergence of the case. You see, it is not fully converged after 40000 time steps. This means after 1.6s or about 100 flow through times. Of course, this is due to very bad initial guess, but you see, this can take some time.
Attachment 34956
I track the energy by putting this in my controlDict:
functions
AverageResolvedKineticEnergyVxVy
        type swakExpression;
        valueType cellZone;
        zoneName FLUID;
        accumulations (
            average
        expression "U.x*U.x + U.y*U.y";
        verbose true;
I only use Ux and Uy for tracking, because I only want to track the kinetic energy of the turbulent structures and Uz is my flow direction. I was too lazy to calculate the average Uz at each point. So this is a fast and good work around.
Could you teach me how to calcukou the magU in paraview?
gu1 is offline   Reply With Quote
Old   December 26, 2017, 15:42
Arnout
The King is on a distinguished road
Paraview is showing the magnitude of the velocity if you have a new enough version.
The King is offline   Reply With Quote
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 07:40
setup problems - LES pipe flow with cyclic BC (1) and direct mapped inlet (2) florian_krause OpenFOAM 22 June 13, 2013 22:25
Pipe flow with pressure-inlet lummz FLUENT 3 October 13, 2012 14:29
Question regarding Fluent's Turbulent Pipe Flow Problem clueless Main CFD Forum 0 May 15, 2009 04:59
Question regarding Fluent's Turbulent Pipe Flow Problem clueless FLUENT 0 May 15, 2009 04:33
