Temperature dependent Viscosity using Power-Law |
November 6, 2014, 19:37 |
Nara Shikamaru
Rep Power: 14 |
I am working on a problem where I have to take into account the temperature dependent viscosity of non-Newtonian fluids. I modified the solver to account for energy equation (similar to posts available in the forum) and tried to implement the power-law model available in FLUENT (http://aerojet.engr.ucdavis.edu/flue...ug/node340.htm). I modified everything similar to work done here (http://www.tfd.chalmers.se/~hani/kur...nFoam%20v2.pdf), except to make it similar to the FLUENT implementation, I changed the part of the viscosity model equation. The pdf file attached has the form in powerLaw.C file for CalcNu() function Code:
Foam::tmp<Foam::volScalarField> Foam::viscosityModels::powerLawTemp::calcNu() const { const volScalarField& T=U_.mesh().lookupObject<volScalarField>("T"); return max ( nuMin_, min ( nuMax_, (k_-ko_*(T-To_))*pow ( max ( dimensionedScalar("one", dimTime, 1.0)*strainRate(), dimensionedScalar("VSMALL", dimless, VSMALL) ), n_.value() - scalar(1.0) ) ) ); } I just modified it to the following form to match FLUENT's formulation- Code:
Foam::tmp<Foam::volScalarField> Foam::viscosityModels::powerLawTemp2::calcNu() const { const volScalarField& T=U_.mesh().lookupObject<volScalarField>("T"); return max ( nuMin_, min ( nuMax_, (k_*exp(T/To_))*pow ( max ( dimensionedScalar("one", dimTime, 1.0)*strainRate(), dimensionedScalar("VSMALL", dimless, VSMALL) ), n_.value() - scalar(1.0) ) ) ); } The 1st implementation works fine but for the second one I am getting errors that I can not resolve or understand why its happening. T is a volScalarField and To a scalar taken as input. I thought the exp() should be able to handle that. Here is the error log - Code:
Create time Create mesh for time = 0 Reading setFieldsDict Setting field default values Setting internal values of volScalarField alpha.water Setting internal values of volScalarField T Setting field region values Adding cells with center within boxes 1((0 0 -1) (0.1461 0.292 1)) Setting internal values of volScalarField alpha.water Adding cells with center within boxes 1((0.2 0.3 -1) (0.3 0.4 1)) Setting internal values of volScalarField T End #0 Foam::error::printStack(Foam::Ostream&) in "/projects/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #1 Foam::sigFpe::sigHandler(int) in "/projects/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #2 in "/lib64/libc.so.6" #3 in "/lib64/libm.so.6" #4 exp in "/lib64/libm.so.6" #5 Foam::exp(Foam::Field<double>&, Foam::UList<double> const&) in "/projects/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #6 void Foam::exp<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/home/OpenFOAM/2.3.0/platforms/linux64GccDPOpt/lib/libmyIncompressibleTransportModels.so" #7 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::exp<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) in "/home/OpenFOAM/2.3.0/platforms/linux64GccDPOpt/lib/libmyIncompressibleTransportModels.so" #8 Foam::viscosityModels::powerLawTemp2::calcNu() const in "/home/OpenFOAM/2.3.0/platforms/linux64GccDPOpt/lib/libmyIncompressibleTransportModels.so" #9 Foam::viscosityModels::powerLawTemp2::correct() in "/home/OpenFOAM/2.3.0/platforms/linux64GccDPOpt/lib/libmyIncompressibleTransportModels.so" #10 Foam::incompressibleTwoPhaseMixture::calcNu() in "/home/OpenFOAM/2.3.0/platforms/linux64GccDPOpt/lib/libmyIncompressibleTransportModels.so" #11 at /projects/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/lnInclude/Switch.H:187 #12 __libc_start_main in "/lib64/libc.so.6" #13 in "/home/OpenFOAM/2.3.0/platforms/linux64GccDPOpt/bin/interTempFoamV2" Allrun.sh: line 8: 17499 Floating point exceptioninterTempFoamV2 > log.txt I can see errors are coming from the calcNu() function but I cant figure out why. Would really appreciate some help if anyone has experience dealing with this before. Regards |
November 8, 2014, 10:20 |
Joachim Herb
Rep Power: 22 |
The error message shows that the problem is somehow related to the exp() function call. So search this site for help:
https://www.google.de/search?q=site%...foam+%22exp%22 Here are two threads, which might help: http://www.cfd-online.com/Forums/ope...t-working.html http://www.cfd-online.com/Forums/ope...ut-scalar.html |
November 8, 2014, 19:37 |
Nara Shikamaru
Rep Power: 14 |
Thank you for the references, I will look them up.
January 6, 2015, 02:47 |
Error while building a new viscosity model..
Himanshu Sharma
Rep Power: 14 |
Hi ,
I am trying to built a new viscosity model based on some scalar like alpha(concentration),T (Temperature) I have tried the following approach given below Code:
/*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | \\ / A nd | Copyright (C) 2011 OpenFOAM Foundation \\/ M anipulation | ------------------------------------------------------------------------------- License This file is part of OpenFOAM. OpenFOAM is free software: you can redistribute it and/or modify it under the terms of the GNU General Public License as published by the Free Software Foundation, either version 3 of the License, or (at your option) any later version. OpenFOAM is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for more details. You should have received a copy of the GNU General Public License along with OpenFOAM. If not, see <http://www.gnu.org/licenses/>. \*---------------------------------------------------------------------------*/ #include "alphaTLaw.H" #include "addToRunTimeSelectionTable.H" #include "surfaceFields.H" // * * * * * * * * * * * * * * Static Data Members * * * * * * * * * * * * * // namespace Foam { namespace viscosityModels { defineTypeNameAndDebug(alphaTLaw, 0); addToRunTimeSelectionTable ( viscosityModel, alphaTLaw, dictionary ); } } // * * * * * * * * * * * * Private Member Functions * * * * * * * * * * * * // Foam::tmp<Foam::volScalarField> Foam::viscosityModels::alphaTLaw::calcNu() const { const volScalarField& T = U_.mesh().lookupObject<volScalarField>("T"); const volScalarField& alpha = U_.mesh().lookupObject<volScalarField>("alpha"); return ((1/Re_)*exp(alpha*(ln(m_))-T)); } // * * * * * * * * * * * * * * * * Constructors * * * * * * * * * * * * * * // Foam::viscosityModels::alphaTLaw::alphaTLaw ( const word& name, const dictionary& viscosityProperties, const volVectorField& U, const surfaceScalarField& phi ) : viscosityModel(name, viscosityProperties, U, phi), //alphaTLawCoeffs_(viscosityProperties.subDict(typeName + "Coeffs")), Re_(alphaTLawCoeffs_.lookup("Re")), m_(alphaTLawCoeffs_.lookup("m")), //nuMin_(alphaTLawCoeffs_.lookup("nuMin")), //nuMax_(alphaTLawCoeffs_.lookup("nuMax")), nu_ ( IOobject ( name, U_.time().timeName(), U_.db(), IOobject::NO_READ, IOobject::AUTO_WRITE ), calcNu() ) {} // * * * * * * * * * * * * * * Member Functions * * * * * * * * * * * * * * // bool Foam::viscosityModels::alphaTLaw::read ( const dictionary& viscosityProperties ) { viscosityModel::read(viscosityProperties); alphaTLawCoeffs_ = viscosityProperties.subDict(typeName + "Coeffs"); alphaTLawCoeffs_.lookup("Re") >> Re_; alphaTLawCoeffs_.lookup("m") >> m_; //alphaTLawCoeffs_.lookup("nuMin") >> nuMin_; //alphaTLawCoeffs_.lookup("nuMax") >> nuMax_; return true; } // ************************************************************************* // Code:
Making dependency list for source file alphaTLaw.C SOURCE=alphaTLaw.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/home/himanshu/OpenFOAM/OpenFOAM-2.3.0/src/transportModels/incompressible/lnInclude/ -I.. -I../twoPhaseMixture/lnInclude -I/home/himanshu/OpenFOAM/OpenFOAM-2.3.0/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/himanshu/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/lnInclude -I/home/himanshu/OpenFOAM/OpenFOAM-2.3.0/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/alphaTLaw.o alphaTLaw.C: In member function ‘Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::viscosityModels::alphaTLaw::calcNu() const’: alphaTLaw.C:57:33: error: invalid initialization of reference of type ‘const Foam::fileName&’ from expression of type ‘const dimensionedScalar {aka const Foam::dimensioned<double>}’ return ((1/Re_)*exp(alpha*ln(m_)-T)); ^ In file included from /home/himanshu/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/lnInclude/regIOobject.H:43:0, from /home/himanshu/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/lnInclude/GeometricField.H:42, from /home/himanshu/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/lnInclude/GeometricScalarField.H:38, from /home/himanshu/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/lnInclude/GeometricFields.H:34, from /home/himanshu/OpenFOAM/OpenFOAM-2.3.0/src/finiteVolume/lnInclude/volFields.H:37, from alphaTLaw.H:40, from alphaTLaw.C:26: /home/himanshu/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/lnInclude/OSspecific.H:170:6: error: in passing argument 1 of ‘bool Foam::ln(const Foam::fileName&, const Foam::fileName&)’ bool ln(const fileName& src, const fileName& dst); ^ alphaTLaw.C:60:1: warning: control reaches end of non-void function [-Wreturn-type] } ^ make: *** [Make/linux64GccDPOpt/alphaTLaw.o] Error 1 Thank you Regards |
non-newtonian, openfoam, power-low, viscosity |
UDF for Temperature Dependent Energy Source | er.mkumar | Fluent UDF and Scheme Programming | 9 | March 14, 2024 05:01 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 07:27 |
Temperature dependent material properties | stuart230588 | CFX | 1 | November 21, 2013 17:36 |
Temperature dependent propertys and finalIteration in chtMultiRegionFoam | waiter120 | OpenFOAM | 0 | February 20, 2013 06:22 |
Viscosity - power law | HOC | Main CFD Forum | 1 | January 15, 2003 16:17 |
