Oscillating inflow/outflow with constant pressure outlet
Old   November 6, 2014, 05:30
Default Oscillating inflow/outflow with constant pressure outlet
Sindre Tosse
stosse is on a distinguished road
Hi fellow foamers.
I am trying to set up a case with constant inflow at several panels at the bottom of a rectangular grid and a constant pressure outlet at the top:
-----------------|XXX|----------------
|AAAAAAAAAAAAAAAAAA|
|AAAAAAAAAAAAAAAAAA|
|AAAAAAAAAAAAAAAAAA|
>AAAAAAAAAAAAAAAAA<
X is a constant pressure (p_rgh) patch with pressureInletOutletVelocity BC for U,
< are constant velocity inlets with zeroGradient BC for p_rgh
A is air (the editor didn't allow me to use spaces)
the rest is walls
For project reasons I am currently using the fireFoam solver, but i think the problem is related to buoyant compressible flow, as the chemical part is not used in the current setup (this is supposed to be a setup of a ventilation flow field to be used in other cases).
What happens when I run the case is that I get a steady increase in pressure in the domain up to some point. Then the pressure decreases (I guess due to the outflow at the top) to the point where the pressure in the domain is lower than the outflow patch. Fluid then starts to flow into the domain, increasing the pressure, and this creates a "steady" oscillating situation with inflow/outflow at the top patch.
Do anyone have a clue about why the simulation does not reach a steady state with regard to the inflow/outflow? I am running at max CFL=0.3.
stosse is offline   Reply With Quote
bcs, compressible flow, firefoam
Pressure Outlet Guage pressure Mohsin FLUENT 36 April 29, 2016 18:16
Pressure correction at pressure outlet (multiphase) shikamaru FLUENT 1 April 6, 2014 03:31
Modeling transient negative pressure (suction pressure) in outlet N_mrtz FLUENT 1 July 18, 2013 21:59
Pulsatile pressure inlet with pressure outlet a.lynchy FLUENT 3 March 23, 2012 14:45
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
