Monitoring Residuals - Initial or Final?
Old   November 3, 2014, 06:26
Default Monitoring Residuals - Initial or Final?
BigPapi34 is on a distinguished road
Very quick question in relation to monitoring residuals of a transient simulation using a dynamic mesh, comparing with CFX.
When monitoring the residuals, should the 'Initial' (-f9) or 'Final' (-f13) be used? I would have thought it was the final however I have seen examples of people using the initial values.
Any thoughts or comments would be greatly appreciated.
BigPapi34 is offline   Reply With Quote
Old   November 3, 2014, 06:31
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
I use the initial residuals. As I understand it, they are a measure of how good the "outer" iterations (i.e. the whole system of equations) are solved. If they are really small, that means, that all your equations are solved quite good.
Now, you take just each single of these equations and solve it. They all are solved idependently and if they are solved well, the final residual of each equation is low. But this doesn't mean, that the "ux" you solved for in "ux-equation" fits to the "ux" that is used in the solution of "uy-equation".
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
High Courant Number @ icoFoam Artex85 OpenFOAM Running, Solving & CFD 11 February 16, 2017 14:40
Cannot run the code properly: very large time step continuity error crst15 OpenFOAM Running, Solving & CFD 9 December 14, 2014 19:17
Unstabil Simulation with chtMultiRegionFoam mbay101 OpenFOAM Running, Solving & CFD 13 December 28, 2013 14:12
rhoSimplecFoam Mach0.8 no pressure values CFDnewbie147 OpenFOAM Running, Solving & CFD 16 November 23, 2013 06:58
Problems with simulating TurbFOAM barath.ezhilan OpenFOAM 13 July 16, 2009 06:55
