A shock appears after several periods of the transient simulation
Old   November 1, 2014, 22:40
Default A shock appears after several periods of the transient simulation
Cai Tao
caitao is on a distinguished road
Hi,I came across a problem when I use the kEplison model to do the transient simulation of flow around a square cylinder.
A shock appears after several periods of the simulation, the shock vibrates every time-step, and the amplitude remains unchanged.
the attachments shows the phenomenon. point E is a monitoring point of the pressure in the wake area of the cylinder. the period is about 0.01s, and the phenomenon appears near the 27th periods.
caitao is offline   Reply With Quote
Old   November 3, 2014, 10:16
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
We need more information.
1) What solver do you use?
2) What do you mean by "periods of the simulation"?
3) Is it possible that you just see a very poorly resolved vortex street?
4) some time steps at the end of your log file
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
Old   November 4, 2014, 06:13
Cai Tao
Hi,RodriguezFatz
thank you very much.
the informations:
(1)the file of fvsolution
solvers
p
solver GAMG;
tolerance 1e-06;
relTol 0.1;
smoother GaussSeidel;
nPreSweeps 0;
nPostSweeps 2;
cacheAgglomeration on;
agglomerator faceAreaPair;
nCellsInCoarsestLevel 10;
mergeLevels 1;
pFinal
$p;
tolerance 1e-07;
relTol 0;
"(U|k|epsilon|R|nuTilda)"
solver smoothSolver;
tolerance 1e-07;
relTol 0;
PISO
nCorrectors 5;
nNonOrthogonalCorrectors 0;
pRefCell 0;
pRefValue 0;
and the file of fvschemes
ddtSchemes
default Euler;
gradSchemes
default Gauss linear;
divSchemes
default none;
div(phi,U) Gauss limitedLinearV 1;
div(phi,k) Gauss limitedLinear 1;
div(phi,epsilon) Gauss limitedLinear 1;
div(phi,R) Gauss limitedLinear 1;
div(R) Gauss linear;
div(phi,nuTilda) Gauss limitedLinear 1;
div((nuEff*dev(T(grad(U))))) Gauss linear;
laplacianSchemes
default Gauss linear corrected;
interpolationSchemes
default linear;
snGradSchemes
default corrected;
fluxRequired
default no;
p ;
(2)"periods of the simulation" means :At first of the simulation, the simulation is correct(there isn't any shock), while after a period of time,the shock begins to appear.
(3)Actually, the transient simulation is based on the result of steady simulation, and I use the software CFX simulated the case, the result is right.
(4)some information of the file "log":
Time = 0.04264
Courant Number mean: 0.122131 max: 1.2103
smoothSolver: Solving for Ux, Initial residual = 4.04218e-05, Final residual = 7.8952e-08, No Iterations 6
smoothSolver: Solving for Uy, Initial residual = 0.0019072, Final residual = 6.09567e-08, No Iterations 12
smoothSolver: Solving for Uz, Initial residual = 0.000173136, Final residual = 8.44166e-08, No Iterations 8
GAMG: Solving for p, Initial residual = 0.000218439, Final residual = 1.89013e-05, No Iterations 8
time step continuity errors : sum local = 4.78031e-10, global = 6.72354e-11, cumulative = -4.2685e-08
GAMG: Solving for p, Initial residual = 8.85436e-05, Final residual = 7.51789e-06, No Iterations 7
time step continuity errors : sum local = 1.90134e-10, global = -2.34216e-11, cumulative = -4.27084e-08
GAMG: Solving for p, Initial residual = 1.66438e-05, Final residual = 1.5961e-06, No Iterations 14
time step continuity errors : sum local = 4.0367e-11, global = -5.13811e-12, cumulative = -4.27135e-08
GAMG: Solving for p, Initial residual = 3.36047e-06, Final residual = 9.43844e-07, No Iterations 8
time step continuity errors : sum local = 2.38714e-11, global = -3.1315e-12, cumulative = -4.27167e-08
GAMG: Solving for p, Initial residual = 1.55151e-06, Final residual = 9.86122e-08, No Iterations 32
time step continuity errors : sum local = 2.49409e-12, global = -3.44097e-13, cumulative = -4.2717e-08
smoothSolver: Solving for epsilon, Initial residual = 1.33639e-05, Final residual = 3.68449e-08, No Iterations 5
smoothSolver: Solving for k, Initial residual = 4.62431e-05, Final residual = 9.74823e-08, No Iterations 6
ExecutionTime = 7549.61 s ClockTime = 8494 s
Time = 0.04268
Courant Number mean: 0.12213 max: 1.21029
smoothSolver: Solving for Ux, Initial residual = 4.03712e-05, Final residual = 7.88954e-08, No Iterations 6
smoothSolver: Solving for Uy, Initial residual = 0.001907, Final residual = 6.09236e-08, No Iterations 12
smoothSolver: Solving for Uz, Initial residual = 0.000173084, Final residual = 8.4416e-08, No Iterations 8
GAMG: Solving for p, Initial residual = 0.000218598, Final residual = 1.88857e-05, No Iterations 8
time step continuity errors : sum local = 4.77668e-10, global = 6.71387e-11, cumulative = -4.26499e-08
GAMG: Solving for p, Initial residual = 8.87166e-05, Final residual = 7.51532e-06, No Iterations 7
time step continuity errors : sum local = 1.9008e-10, global = -2.34088e-11, cumulative = -4.26733e-08
GAMG: Solving for p, Initial residual = 1.66435e-05, Final residual = 1.59465e-06, No Iterations 14
time step continuity errors : sum local = 4.03328e-11, global = -5.13204e-12, cumulative = -4.26784e-08
GAMG: Solving for p, Initial residual = 3.35917e-06, Final residual = 9.41966e-07, No Iterations 8
time step continuity errors : sum local = 2.38254e-11, global = -3.12867e-12, cumulative = -4.26815e-08
Old   November 4, 2014, 07:52
Philipp
Hi again,
1) I still don't get what you mean by "period". Do you see periodic vortices in the wake of the body and the period T = 0.01s?
2) In the log file you show information of time = 0.04264. In your upper picture the whole pressure-mess starts at time = 0.27s. Can you show the log output of a time step when - what you call a "shock" - is already there?
3) Your max. Co. > 1. Does this all happen if you use a smaller time step? Try to halve the time step!
4) What about changing to safer numeric schemes? Such as upwind and uncorrected laplacian?
Old   November 5, 2014, 08:27
Cai Tao
Hi,RodriguezFatz
1) the period T = 0.01s is base on the st(Strouhal number)of Flow around a cylinder which value is 0.2. The diameter of my model is 0.2m, and the U∞=10m/s. So the f=0.01hz.
2)I show information of time = 0.04264 is another case, but it also have the same phenomenon at that time step.
The good news is that I change the mesh, the y+ is increased form 30 to 49. i didn't change any other sets, and the shock phenomenon disappeared. i think the Co may be the cause of the shock phenomenon.
Old   November 6, 2014, 07:19
Philipp
You say the log output is during what you call "shock". But the simulation is converged... this doesn't look like a CO-problem. For CO-problems the simulation diverges and explodes.
Old   November 8, 2014, 09:38
Cai Tao
Thank you again.
I just change the mesh(do not change any other settings), and then the phenomenon disappears. I still look for the reason that lead to the phenomenon.
keplison, shock, transient simulation
Transient RANS Simulation Bazinga Main CFD Forum 5 June 21, 2017 12:21
Question on transient simulation in OpenFOAM and FLUENT nicklj OpenFOAM Running, Solving & CFD 4 May 8, 2014 23:30
Exporting data of transient simulation DURING a simulation, at user locations ? Milan2013 CFX 0 April 18, 2014 04:47
Synthetic (pulsatile) jet transient simulation aero CFX 0 November 6, 2009 02:10
how to identify transient simulation converged littlelz CFX 5 January 27, 2009 19:13
